E-Brake failure.....HELP
Old Jun 26, 2007 | 02:04 PM
Dan9687's Avatar
Dan9687
Default E-Brake failure.....HELP
My E-brake is failing bad at its job. It wont hold my car at all when I put it up. In fact, the whole E-brake unit in the inside of the car where you wrap your hand around the lever is loose and not attached. Basically, it is done for.....trash. How much for a new one installed at somewhere like a Ford dealership or something cheaper for the money.
Old Jun 26, 2007 | 09:35 PM
blackstallion666's Avatar
blackstallion666
Default RE: E-Brake failure.....HELP
https://fordparts.com/oe_parts_catalog.html
that part is $50 plus shipping through ford parts.com and as long as you have basic tools you should be able to do it yourself. If you went to the shop im sure they'll charge you from 70-90- for the part and atleast and hour and a half to install it. labor rate by me is around $90 so your probably looking at $200 - 250 for a shop to install it for you.
Old Jun 30, 2007 | 06:04 AM
stang707's Avatar
stang707
Check to see if its recalled. I think 99- mid01 stangs have recalled e-brakes.
Old Jul 7, 2007 | 11:03 PM
Dan9687's Avatar
Dan9687
If it is a recalled product will Ford fix the problem free of charge even now in 2007???
bond007
Aug 26, 2015 11:36 PM
paulfm5.0
Jun 24, 2006 02:28 AM
mpk4580
Jun 1, 2006 01:28 PM
98faleen
Feb 1, 2006 10:37 AM
