Predator config changes
Old Jan 15, 2005 | 04:00 AM
jishead's Avatar
jishead
Default Predator config changes
When using a Predator, how easy is it to switch running configs? I don't need to change configs while driving down the road but would it be quick and easy to revert to near stock timing to burn 87oct for a while and then later get back your configs that your worked so hard to tweak on the dyno and burn some 92oct most of the time?
Take a look at my mods in my profile. What gain at the crank could I expect with a predator and several dyno runs and no additional hardware/mods?
Old Jan 15, 2005 | 04:14 AM
jishead's Avatar
jishead
Default RE: Predator config changes
Sounds like it would be pretty easy:
http://www.diablosport.com/downloads/manual_U7146.pdf
Old Jan 17, 2005 | 12:11 PM
propellerhead's Avatar
propellerhead
It takes about two minutes to load a tune (config, as you call it).
Old Jan 17, 2005 | 03:49 PM
Ontherocks98's Avatar
Ontherocks98
i keep hearing things about the predator tuner....so is it worth the money?
Old Jan 17, 2005 | 04:10 PM
propellerhead
Aside from the gains in HP and torque from the base tune, you save yourself $80 on a speedcal if you swap gears, $60 on MIL Eliminators if you get an off-road midpipe, $120 on a timing adjuster, $50-300 on a shift kit if you have an auto, and you can make adjustments to it all day long. If you know what you're doing, you can tweak the tune and squeeze out a little more HP/torque.
dubarado
Dec 23, 2015 01:16 PM
Mnuckolls
Aug 9, 2015 08:54 AM
NinoAvila
Feb 8, 2005 04:33 PM
Bowdy04
Nov 13, 2004 01:10 PM
propellerhead
Oct 21, 2004 12:40 AM
