Thermostat help!
Old Jan 21, 2005 | 06:36 PM
devinsteen's Avatar
devinsteen
Default Thermostat help!
Yeah....I kinda stripped one of the bolts on the thermostat housing. The othe came off fine, but I fvcked the other one.[:@] Can I get a new bolt at any auto parts store or do I have to go through Ford?
Old Jan 21, 2005 | 06:49 PM
USAMuscle's Avatar
USAMuscle
Default RE: Thermostat help!
Those are the long bolts right? You can go to a hardware store, take the bolt with you, and see if they have one that matches the length. Thread pitch and size is standard throughout the industry so for instance a 13mm bolt is a 13mm bolt regardless of who manufactures it. It's probably metric just FYI. If you can't find it at a hardware store try to find a fastener warehouse near where you live and get one there. I used to work at a fastener warehouse and believe me they can get anything. If you can find one at a hardware store though it should cost less than a buck for just one bolt.
Old Jan 21, 2005 | 07:47 PM
vfast's Avatar
vfast
I ♥ Acer
lowes carries some bolts did you strip the thread in the block also?..
Old Jan 21, 2005 | 08:23 PM
89stanglx's Avatar
89stanglx
Your lucky i snapped the head of one of mine now im stuck with the stud in my manifold.
Old Jan 21, 2005 | 08:29 PM
vfast's Avatar
vfast
I ♥ Acer
use an easyout on the bolt dude
Old Jan 23, 2005 | 05:36 AM
devinsteen's Avatar
devinsteen
ORIGINAL: vfast
What is that? I can't get the damn thing out.....I don't own a drill so I need a shop to do it[:@]
Old Jan 23, 2005 | 11:04 AM
vfast's Avatar
vfast
I ♥ Acer
a man has to own a drill...*L* it's a must
Craftsman 7 pc. Drill-Out/Screw-Out Power Extractors
Sears item #00952157000 Mfr. model #720SR
Drill-Out removes broken bolts that are snapped/broken off. Screw-Out removes damaged screw heads without damaging surrounding material. Easy to use 2-step process. Requires 3/8 in. reversing drill.
[IMG]local://upfiles/1534/E59FA82D13BE48F9B1C7BB9D9A8922FD.jpg[/IMG]
if any of the bolt is stickin out try a pair of channel locks but spray the bolt with something to loosen rust
Old Jan 23, 2005 | 02:25 PM
BlackMage's Avatar
BlackMage
PB Blaster, and depending on which bolt u stripped, try getting some vise grips in there, and make sure they are very tight, and if worse comes to worse, do what my friend did, use a ball peen hammer to remove his doorhandle , lol dont ask
Old Jan 23, 2005 | 05:09 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
Hmmm.... First i would try vise-grips on it. I have the same car so i know what youre taling about. I have never had this problem though. lol.
Also try whacking the top of the bolt with a hammer, then heat it up and use a crayon and melt the crayon on the bolt. It will get down inside the threads and it will come right out.
Also you could try a Gator-grip or craftsman brandname tool also.
Just a few thoughts. I've had even worse luck, so dont feel bad
I had a 1.9 escort at work a few weeks ago, i went to "fix" another techs mess up. He already put a thermostat in but didnt replace the gasket. So it leaked. I went to take the bolt out and it broke in the head, because the tech before me striped it and just reamed it into the head and thought it would never come back. lol.
So i had to drill, tap and it took me about 4 hours and i got paid 1.5
Old Jan 23, 2005 | 07:48 PM
vfast's Avatar
vfast
I ♥ Acer
that's when it need to go back to that tech for no pay..why should the cust paid for his f'uk up....this is why I quit working in the field
Nick Oliver
Oct 17, 2018 04:22 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Wesley1995
Aug 30, 2015 02:01 PM
