Alternator problem, I'm out of ideas?
Old Feb 8, 2005 | 03:44 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Alternator problem, I'm out of ideas?
also do not pull the battery cable while running this will interfear with the computer and when you put it back on could cause a spike and fry the 'puter ..it's not like the old days[:@]..I would check your ground also....
Old Feb 13, 2005 | 11:30 AM
johnwads's Avatar
johnwads
hey im having the same prob in my 92 lx 4 cyl.. headlights on heater on.. come to a stop sign and everything goes way down. was reading here to see what i might start at? just started happening a month or so ago ran fine before
Old Feb 13, 2005 | 08:45 PM
aamilo's Avatar
aamilo
Yea John, its weird. Went out replaced the positive bat. cable no difference. Negative looks just fine but a solid cleaning made the problem go away kinda???? The problem has become intermittent. I am sure it is a grounding problem somewhere because I have swapped out the alt. battery, positive cable etc. and it still exists. Negative cable is next and then????????? If i solve the problem I will let you know.
articman
Jun 21, 2018 11:45 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
amandahchase
Sep 3, 2015 10:09 AM
