Engine Idle Speed
Old Dec 28, 2007 | 08:05 PM
87Stallion's Avatar
87Stallion
Default Engine Idle Speed
My timing wasn't set correctlyon my 87 GT, so I got my light and set my base timing to 12 Deg and now my engine idles at 1100 RPM. The idle screw is all the way out and its still that high. I did disconnect the spout connector before setting timing. Any ideas? Also what RPM should these cars idle at with 5-speed?
Old Dec 28, 2007 | 11:03 PM
93_five_oh's Avatar
93_five_oh
Default RE: Engine Idle Speed
idle should be around 750 i believe. could the iac be stuck open? umm... check you throttle position sensor.
Old Dec 31, 2007 | 04:43 PM
87Stallion's Avatar
87Stallion
I just checked the voltage on TPS and IAC is new and has been cleaned? Idles @ about 1000 RPM with spout connector un-hooked and then when I plug it in it advances the timing to about 22 degrees @ Idle and therfore Idle speed goes up. Could spout connector be bad?
Old Jan 3, 2008 | 01:46 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Is the car warmed up when you set the idle?
Old Jan 3, 2008 | 03:30 PM
87Stallion's Avatar
87Stallion
Yeah it was. It ran for about 30 min before I did it. I only run a 180 thermostat so it doesn't get real warm.
djbigskrilla
Sep 20, 2022 01:04 AM
msavoia23
12
Jul 7, 2018 12:08 PM
drfister
May 3, 2018 10:38 PM
1987gt40ttopt
Aug 28, 2015 10:49 PM
HIS S-197
Aug 10, 2015 05:47 PM
