Air bad light?
Old Mar 28, 2005 | 05:29 PM
96SilverLT1's Avatar
96SilverLT1
Default RE: Air bad light?
if I remember right the code 12 comes from an interuption of battery power to the module. Did you have the battery drained at any point to where it would have had low voltage?
Old Mar 28, 2005 | 05:54 PM
94droptop's Avatar
94droptop
i think that my brother in law who helped me put a new engine in forgot to hook up the high voltage power or something like that? i went to a mechanic when i had a check engine light on and he noticed it was not hooked in a plugged it in, then the air bag light came on he said it could have happen through a voltage spike or something like that how do i fix it?
Old Mar 28, 2005 | 06:00 PM
96SilverLT1
unhook both battery cables and touch the cables together. This will drain the PCM and related modules and clear all codes from memory. Then hook it all back up and see what happens (note, the car might run funny for a little bit untill the adaptives are relearned)
Old Mar 28, 2005 | 06:05 PM
94droptop's Avatar
94droptop
that worries me that wont short out anything. have you done this before. i am not denying you know your stuff i am just making sure, i just had to pay 2000 for a new engine i dont wnat to have to worry about electrical
Old Mar 28, 2005 | 11:48 PM
96SilverLT1
as long as the battery is totaly dissconected then it's fine. It's actualy the only way to clear some emissions codes without a scanner. What your doing is alowing the small amount of "KAM" (Keep alive memory) for the computer to spread through the ground disipating it. If your really really nervous about it you can unhook the batery and press the brake pedal. It does basicly the same thing but doesn't always work.
Old Mar 30, 2005 | 12:53 AM
94droptop's Avatar
94droptop
so i disconnect the main cables from the battery( the wires with the terminals on them) and touch them together, do i have to diconnect all the small ground wires attached to the cable
Old Mar 30, 2005 | 03:22 PM
94droptop's Avatar
94droptop
still is on? didnt work? any one in here work for ford
djbigskrilla
Sep 20, 2022 01:04 AM
67LimeCoupe
Nov 25, 2015 08:55 PM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
mweiland
Aug 16, 2015 10:59 AM
