Changing cam in 83 mustang
Ibought a t-top 83 mustang gt. It has a 86 5.0 in it. The fuel injection has been replaced with a600 carb. I want to change the stock cam to something with a little more "lope". I found a voodoo cam that I think might work. I'm not sure on the valve to piston clearence.The motor has stock heads. Can some on tell me if this cam will work without having to notch the pistons? Here are the cam specs?
Operating Range
1500-6500 RPM
Duration Advertised
290° Intake/300° Exhaust
Duration @ .050'
224° Intake/234° Exhaust
Lift @ Valve
.496' Intake/.520' Exhaust
Lift @ Cam
.310' Intake/.325' Exhaust
Lobe Separation Angle
112°
Intake Centerline
107°
Intake Timing @ .050"
Open 5° BTDC
Close 39° ABDC
Exhaust Timing @ .050"
Open 54° BBDC
Close 0° ATDC
Operating Range
1500-6500 RPM
Duration Advertised
Duration @ .050'
Lift @ Valve
Lift @ Cam
112°
Intake Centerline
107°
Open 5° BTDC
Close 39° ABDC
Open 54° BBDC
Close 0° ATDC
