WHAT THE HE...
Old Apr 18, 2005 | 03:48 PM
gmkilla's Avatar
gmkilla
Default WHAT THE HE...
Allright, drivin my car for the first time of the season and every time I take off from a light normally (this doesn't happen, or at least i don't hear it when i mash on it) there is a loud noise. Hard to describe, but it is a hollow metal sound. I do have an aluminum driveshaft, and i didn't notice the noise before hand, but I figure the aluminum resonates the sound more. We had the car on the lift and still can't even tell were it is comin from. My tranny is new, i don't think that is the problem, i was thinking maybe it was gear slap in the rear end or excessive play, but then i should hear it when i let off the throttle too. It happens every time i shift to, but not right away, its fine until i give just a little more gas, then it does it, not as loud but more lie a snapping noise. I cannot find anything hitting anywhere, and our best guess is the rear end (which is still a 7.5 by the way, 8.8 going in this week i guess.) Anyone had a similar problem? Thanks.
Old Apr 18, 2005 | 05:46 PM
fordguy17's Avatar
fordguy17
Default RE: WHAT THE HE...
it might be pinging. run higher octane, and tighten all exhaust bolts to see if it goes away. also lower your timing to like 11-12 if you are running 87. check this first, then exhaust, and then run high octane.
Old Apr 18, 2005 | 07:20 PM
gmkilla's Avatar
gmkilla
Thanks for the advice, but ain't it. One thing i just noticed is that my rear end also isn't locking like it used too...suspicious...maybe I broke something?
Old Apr 18, 2005 | 07:51 PM
Valcore's Avatar
Valcore
I had the same noise/problem, I had the front, and back universals done and the problem is gone...
Old Apr 18, 2005 | 07:54 PM
92hatchLX's Avatar
92hatchLX
Sounds like U-Joints, mine was doing that also so I replaced both of them and it went away.
Old Apr 18, 2005 | 08:13 PM
Aliate X's Avatar
Aliate X
I ♥ Acer
ORIGINAL: gmkilla
e had th
Does it sound like the noise that the predator makes in the movies?
Old Apr 18, 2005 | 08:18 PM
gmkilla's Avatar
gmkilla
Driveshaft and u-joints are brand new, but i'll check them out.
Old Apr 18, 2005 | 08:30 PM
92hatchLX's Avatar
92hatchLX
Alright, well if they're new then that shouldn't be the problem, did you grease you're ujoints? I'm all out of suggestions.
Old Apr 18, 2005 | 08:34 PM
Sickspackstang's Avatar
Sickspackstang
i have the same problem, i also have a aluminum driveshaft, i think its the rear diff u-joint and then resonating over the shaft, i think this should help
Old Apr 18, 2005 | 10:15 PM
33boggers's Avatar
33boggers
I went to the track fri night. sat I heard a tapping sound wen't away when I pushed the clutch in, also been having a lot moor vibration at higher rpm. I replaced the throwout bearing (which i just replaced withthe tranny two month ago) Ialso used the bering retainer from my outher t-5 cause the one was toue up?? runs fine now
kweb288
Sep 21, 2009 03:43 PM
MattyJ
Nov 26, 2008 08:30 AM
coop7
Oct 12, 2008 02:00 PM
05SDI
Jun 6, 2007 12:09 PM
Shifty Powers
Feb 27, 2006 04:35 PM
