Sticky Pedal
Old Sep 7, 2008 | 08:01 PM
hokiefan's Avatar
hokiefan
Default Sticky Pedal
Got another weird problem on my 87 5.0. I used a commercial engine cleaner on her yesterday. Got the engine looking nice for the most part, and now my gas pedal sticks. Not while I'm giving her gas, just on the initial push, and every time i let go of the pedal and press down again during shifting. Almost seems like it is stuck until you give it enough pressure to get past that initial stick. Any Ideas would be greatly appreciated.
Thanks.
GO Virginia Tech
Old Sep 7, 2008 | 08:04 PM
princessturtle's Avatar
princessturtle
probably some of the chemical stuff got inside ths shaft seal on the throttle body. spray some like penetrating oil. like wd 40 down inside of it. should fix it. =)
Old Sep 7, 2008 | 08:32 PM
Jfsram's Avatar
Jfsram
If lubing the throttle body shaft does not fix it.
Check the blade to see if it's getting stuck in the throttle bore.
Cleaning the black **** inside should help.
If it is the throttle blade and cleaning doesn't help. You may have to add a bit of throttle stop, just a touch, like 1/8th of a turn.
Old Sep 9, 2008 | 10:50 AM
hokiefan's Avatar
hokiefan
Got her fixed up. Shaft was sticky and the WD 40 Worked just fine.
Thanks for all the help
Hokiefan
Old Oct 7, 2008 | 05:03 PM
MotoLappa's Avatar
MotoLappa
I got this same problem. Where is the shaft seal? Wher am I spraying?
Old Oct 8, 2008 | 10:46 AM
hokiefan's Avatar
hokiefan
Underneath of the throddle body on the throddle linkage right beside the idle screw. Looks like a long spring with a cable inside of it.
Thunderball
15
Nov 22, 2015 11:49 PM
piotrek53
Oct 13, 2015 06:54 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
col2560
Sep 25, 2015 06:51 AM
ccdguy
Sep 19, 2015 05:20 PM
