HEAD LIGHTS?
Old Nov 24, 2008 | 01:56 PM
rockstar1725's Avatar
rockstar1725
Default HEAD LIGHTS?
i got an 01 gt and my headlight have major oxidation and iv tried everything to remove it, so i was curious if anyone knows any sites that i could jus find the lenses only and not the whole headlight.
Old Nov 24, 2008 | 02:20 PM
GreyStang's Avatar
GreyStang
The lenses are "glued" or bonded together & tough to split apart.. try some of the aftermarket sites, replacment assemblies aren't too expensive
Old Nov 24, 2008 | 02:49 PM
92stangerang's Avatar
92stangerang
you tried wet sanding and hi speed buffing?
Old Nov 24, 2008 | 10:29 PM
stanggurl007's Avatar
stanggurl007
i dont know what you've found out about just the lenses but i found a set of 2 smoked headlight assemblies and bulbs for 125 on blueovalindustries.com . i was really satisfied with they're service. you might try contacting them about new assemblies. the smoked ones i got were less then the OE assemblies for my 99. good luck with the search.
Old Nov 25, 2008 | 10:28 AM
IRSmart's Avatar
IRSmart
or i have a set of smoked projector headlights with 6000K HIDs for sale if you'd like to upgrade
Old Nov 25, 2008 | 11:08 PM
khooper's Avatar
khooper
You can buy a special headlight polishing kit. It will contain a hard buffing wheel and some special compound. It will work, but the part that is oxidizing is the "hard" layer of the headlight. Once you remove the oxidation, the coating is gone too. Basically, it will continue to pit with road debris.
_______________________
Check out this car parts sale
Old Nov 26, 2008 | 09:37 AM
ttocs's Avatar
ttocs
take it to a detail place and ask them how much they would charge to buff them. It only takes them 2 secs, very little material(buffing compound) and they will look almost new.
Old Nov 26, 2008 | 11:43 AM
ttocs's Avatar
ttocs
I was in autozone this morning picking up some glazing putty and sanding supplies when I noticed something that made me think of this. They have a kit there made by 3m that hooks onto a drill, comes with the sanding disks, buffing disks and compound and it was on sale for only $17.
Old Nov 26, 2008 | 03:53 PM
socaljk's Avatar
socaljk
I got the head light renew kit from Kragen. Cost me about $12. It includes 4 different grit sand paper as well as a plastic coating to replace the hard coating. Took me around half an hour to do the lights and they are almost as good as new. Much cheaper than new headlights.
MasterLanMan
21
Sep 16, 2015 03:26 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Blk Vert
Sep 9, 2015 12:16 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 04:12 PM
