help with thermostat, urgent
Old Dec 15, 2008 | 04:13 PM
bfootdude's Avatar
bfootdude
Default help with thermostat, urgent
Hey just got my 98 cobra back from getting a new engine in. This happens when i start driving after the car has been given time to cool off. The temp gauge goes almost to the red line and hangs there for a few minutes around that area. Then after that it seems to go back to normal operating temp and stays there even in stop and go traffic. The fan does come on and that is why the car gets back down to its normal temp.
The shop owner said they put a new thermostat in it. Could that be the problem?
I searched around and didnt find anything with these details and I am at work so i dont have much time to search anyway.
also is it ok to drive like this? it's my daily driver
Thanks in advance.
Old Dec 15, 2008 | 04:33 PM
bfootdude's Avatar
bfootdude
also just got off the phone with the guys at the ford dealership and he said it is probably air in the system and just to drive it and they should make their way out over time.
He also said its is fine as long as its not drastically changing temps.
*the temp gauge fluctuates smoothly and doesnt dart around*
Old Dec 15, 2008 | 05:58 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Our cars are the HARDEST to burp free of air. If he didnt use a vacuum filler, then it most likely still has some air in it. If its not actually overheating, then drive it around and see if it burps out. I always use a vacuum filler on my car, and it works great
Old Dec 21, 2008 | 09:12 AM
Jfsram's Avatar
Jfsram
The dealer is correct in saying a perfectly functioning cooling system will rid itself of air after a few cycles.
When it's hot and expells into the recovery resorvior. It expells the air FIRST. When it's cool and it pulls fluid in. It pulls from the bottom of the recovery tank. As long as it's full it will pull straight liquid FIRST.
Now if you have a leak, sometimes this cycle will not work 100% because it may pull in air before it sucks from the recovery tank.
Check the recovery tank level. If it stays at the full mark after 10 or so cycles. You're good.
Old Dec 21, 2008 | 09:52 AM
forcefeed's Avatar
forcefeed
Thanks in advance.
driving it until it burps the air out is a big mistake, you need to stop driving it and have the air purged from the system. the best way to do this is to use a tool called an air lift, take it back to whom ever did the motor for you and get them to finish the job properly!! do you honestly think it healthy for your engine to over heat it continually?............
Nick Oliver
Oct 17, 2018 04:22 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Wesley1995
Aug 30, 2015 02:01 PM
