Sponsored by:
Sponsored by: DashLynx
Rear Brake Caliper Piston Stuck?
Old 03-05-2009, 09:12 PM
RDP
RDP's Avatar
Default Rear Brake Caliper Piston Stuck?
So I was changing the brake pads on my 2002 V6 Mustang (stock brakes and all that, nothing fancy) I got all the calipers off and put on the new pads but when I was trying to compress the piston on the rear brake caliper it just will not compress at all. The caliper just will not fit back into place, due to the piston sticking out to much.
Any ideas? I have a Chilton Guide
Should I look at taking the caliper apart and seeing if it is in fact stuck? maybe spray it with some liquid/solvent to clear out some dust?
RDP is offline
Old 03-05-2009, 09:58 PM
Choppa
Choppa's Avatar
ya try that sum guys say that u need sum tool ive never needed anything more then a c-clamp but on my first v6 the small pistons (not the big one in the middle) actually rusted and were stuck in one spot so my rear brakes pretty much were worthless remove the little rubber covers and take a look that was my prob
Choppa is offline
Old 03-05-2009, 10:26 PM
MustangLouver
MustangLouver's Avatar
I have a brake tool, it compresses the piston enough to get them back on.
MustangLouver is offline
Old 03-05-2009, 10:45 PM
RDP
RDP's Avatar
Thanks, I will try that Choppa.
How much was the brake tool?
Does a place like Checker Auto sell it?
RDP is offline
Old 03-06-2009, 02:34 PM
GreggBig
GreggBig's Avatar
The rear brake piston does not compress like the fronts (Different manufacture). The rear must be screwed back using a tool from AutoZone or like. Approx $12.
Using a c-clamp can distroy the piston.
GreggBig is offline
Old 03-06-2009, 02:40 PM
GreggBig
GreggBig's Avatar
I did a quick search and found this:
https://mustangforums.com/forum/6-cy...rake-pads.html
I know there are better "how to's" about this somewhere in MF. That's what I used when changing mine and it went perfect.
GreggBig is offline
Old 03-07-2009, 04:05 PM
RDP
RDP's Avatar
Thanks GreggBig, the tool did the trick and my brakes seem to be working just great.
Thank you all for the help
RDP is offline
Old 03-08-2009, 01:56 AM
taker52
taker52's Avatar
you never spray anything ever on to you brakes just if you caliper is stuck and wont work try a few times just get a new one
taker52 is offline
Tivo304
08-28-2023 12:19 PM
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Rear Brake Caliper Piston Stuck?
