I need some help with a Blinker problem.
Old Aug 23, 2009 | 05:11 AM
jimmybutters's Avatar
jimmybutters
Question I need some help with a Blinker problem.
I have a 2000 Mustang GT,
My blinkers are acting up. Sometimes they blink really fast and some times they pause for a sec then start fast again. There are no burned out bulbs. I am confused, and they are not going to let me pass my inspection untill they are fixed. There is one thing about 7 - 8 years ago the person that had it before me had the tail lights re-wired for the japanese inspection. The japanese require the reverse lights to be the blinkers and have a external reverse light installed.
Any help would be great! Thanks
James the Newbie
Old Aug 23, 2009 | 06:57 AM
a_penquin's Avatar
a_penquin
Did you check the blinker fluid? lol, j/k Sounds to me it may be a bad ground or short in the system.
Old Aug 23, 2009 | 07:29 AM
jimmybutters
Default thanks
Thanks,
Do you know how I could check where it might be coming from?
Old Aug 23, 2009 | 07:30 AM
a_penquin's Avatar
a_penquin
follow the power o.0 I normally work from the ground back.
Old Aug 23, 2009 | 01:31 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
You can also try the silinoid under the dask. On my 85 the blinkers would speed up when the silinoid was wearing out....
Matthew
Old Aug 30, 2009 | 04:36 AM
jimmybutters
Default Thanks
Thanks everyone for the help. I took the car to the local japanese ford dealership and they told me its because of my aftermarket radio. I laughed at them and went on my way. I then went to a small garage close to where I live and they said when I turn on my blinker its suppose to make a slight clicking noise as it blinks but mine don't do that so they told me I should change out the the blinker switch on the steering wheel. Do you think that could be the problem instead of a short somewhere. Over here in japan its hard to get parts so I want to try to make sure what it could be before I purchase something.
thanks in advance!
Old Aug 30, 2009 | 10:05 AM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Could be your turn signal switch.
Edit: Just read your last post, I would try that, I believe mine just went out on me this week. Lost my blinkers completely, checked all fuses, wiring, only thing left is the switch.
Old Sep 2, 2009 | 01:30 AM
hiboostwoody's Avatar
hiboostwoody
It's the electronic turn signal flasher unit behind the instrument panel. Kinda like a circuit breaker.
Old Sep 2, 2009 | 01:27 PM
GreenMachine19's Avatar
GreenMachine19
sometimes when it flashes fast it is a indicator that you have a bulb out
Vrooom
Feb 21, 2016 05:25 PM
69Volunteer
Sep 30, 2015 10:39 AM
bconboy
Sep 24, 2015 01:55 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
