Sponsored by:
Sponsored by: DashLynx
Door Panel Removal
Old 07-16-2005, 08:37 PM
95 Green Machine
95 Green Machine's Avatar
Default Door Panel Removal
Hey, I am band new to the forum and looking for help removing the door panel. I got everything off except the manual handle to roll the window up and down. It's a 95. Anybody got any answers for me??? Do I need a special tool to remove this handle?
95 Green Machine is offline
Old 07-17-2005, 12:36 AM
Chopper
Chopper's Avatar
Default RE: Door Panel Removal
I don't know for sure but the older GM's had a clip that you had to pull out to get the window handle off.Then when you put it back on you install the clip and push the handle back on.You could make a tool out of welding rod by bending a small hook into the end.I don't know if this will help you or not.
Chopper is offline
Old 07-17-2005, 06:16 AM
MikeHawke
Retired MF Moderator
MikeHawke's Avatar
yeah. there should be a clip in the back and there is a special tool for this and it's cheap but you can probably wrestle it off there if you try really hard. Try to pry the door panel away from the window crank so you can see what's back there. Be careful you don't pry too hard and break something though.
MikeHawke is offline
Old 07-17-2005, 04:17 PM
justingt
justingt's Avatar
If all else fails get a Hayne's manual. Idk why you're taking off the door panel but you sound like a DIY guy and could prolly use it for future stuff. good luck
justingt is offline
Old 07-17-2005, 06:43 PM
99saleen351r
99saleen351r's Avatar
I think there is a cover over the handle if you feel the edge of the handle part not the **** you should be able to pull the cover off and turn it to the side then under it there is a torqes bolt that you remove and slide it off the shaft.Or it could be the way everyone else said and you can push a pin out behing it ,there is a spring loaded cover that moves back so u can see the pin and knock it out
99saleen351r is offline
jerrytubes
10-23-2015 12:11 PM
b8checker
10-08-2015 12:55 PM
jrrhd73must
10-02-2015 09:17 PM
breaking
10-02-2015 01:27 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: Door Panel Removal
