How to change Ford 351w with Automatic to Manual transmission?
I have a 351W engine that I want to put on a Manual transmission, I was wondering if there is anything I need besides the transmission? or does anyone know any Fords that have the same engines so that I could go to a Pick and Pull and take the whole assembly, that would be better I think.
You will need the clutch and brake pedal assembly from an early Mustang or Cougar, a flywheel and clutch assembly, a starter for a manual transmission car, the clutch linkage assembly from the pedals to the clutch fork, correct length driveshaft with the correct slip yoke, the correct crossmember, and a shifter. You can use a transmission from any 6bolt bellhousing smallblock. These would include 289, 302, 351W, and 351C as well as the 300 6 cylinder.
Thanks for the info. Another thing I was wondering if the newer transmissions would fit to the car like a T5 transmission for the 1990 5.0 Mustang or so? I have a 351 stroker engine and I want a good transmission that is built for that kind of power.
1995, 351w, auto, conversion, differences, engine, exhaust, f350, good, manual, problem, tranny, trans, transmission, transmissions
