Replacing t5 1-2 shift fork
Old Nov 15, 2009 | 10:53 AM
crzydrumer14's Avatar
crzydrumer14
Default Replacing t5 1-2 shift fork
So ive bent my shift fork going from 1st gear to 2nd. Is this a job that i can do by myself? or... am i going to have to take it somewhere? Also, if i can do this by myself anyone have a diy of the process. Thanks
Old Nov 15, 2009 | 03:47 PM
hiboostwoody's Avatar
hiboostwoody
Unless you have a lot of knowledge in rebuilding manual transmissions, your best bet is to take it to someone that does. You can save yourself a bunch of money by taking it out of the car yourself, though. Might as well check the clutch and rear main seal while you are there since the tranny is already out.
Old Nov 17, 2009 | 03:33 PM
crzydrumer14
gay... how much you think?
Old Nov 18, 2009 | 12:06 AM
hiboostwoody
Don't know. Every area is different and the labor rates can be all over the board. I'd do some calling around to some of the local transmission shops to see what they charge.
Old Nov 29, 2009 | 11:54 AM
RUDEDOG.357's Avatar
RUDEDOG.357
If it was a T-5 i would say it was easy. but i think your vehicle has the T-45 which you have to split trans to get at the forks.
Old Nov 29, 2009 | 12:33 PM
hiboostwoody
All the more reason to take it to a shop. You may not even know what transmission you have. Not a jab at you, just being truthful.
CMcNam
Oct 30, 2022 11:40 PM
Thunderball
15
Nov 22, 2015 11:49 PM
5.0 kevo
Sep 3, 2015 06:24 PM
Tyoung68
Aug 25, 2015 04:31 AM
Mnuckolls
Aug 9, 2015 08:54 AM
