Ignition Problem
Old Sep 17, 2005 | 06:08 PM
HRnB's Avatar
HRnB
Administrator
Default Ignition Problem
My 03 just did something very strange. My son asked to use my Stang because we're working on his truck and he went out to start it and the key goes in fine but it feels like the ignition switch is free spinning when you try to start it and it won't start. I've never had a mechanical ignition switch ever break on a car before and I'm wondering if it could have something to do with the Anti theft system. The reason I think it's the Anti theft is because the keyless alarm buttons do not work on either of the hand held units and it acts like it is in the accessory position because the radio is on and the instrument panal is lit up. Has anyone ever had this prob? [&:]
Old Sep 17, 2005 | 10:05 PM
4600cc's Avatar
4600cc
I ♥ Acer
Default RE: Ignition Problem
That is very interesting indeed. Does reprogramming key pads do anything at all?
Old Sep 18, 2005 | 09:14 PM
HRnB's Avatar
HRnB
Administrator
I'm going to call round on Monday. I'll post it when I find out. I just can't help but think it's something to do with the anti theft syst. But it could be a broken ignition key barrel.
Old Sep 19, 2005 | 05:17 AM
ShadowDrake's Avatar
ShadowDrake
It's very likely not the anti-theft system. It doesn't disengage the key-turn when it's on... It turns off the spark so the starter will crank it but it won't start. I had a problem with my anti-theft system (because of a new instrument cluster) about two weeks ago.
When they key is in the on position (I'm not sure about accessory too) the buttons on the keypad won't do anything (in case, say, the trunk release button gets pressed while driving, that could be bad). I'd place my money on a broken key barrel.
Edit: Just went out and tested with my dead key, fuel pump will start to give pressure but there is no spark, so no combustion!
Old Sep 19, 2005 | 07:27 PM
HRnB's Avatar
HRnB
Administrator
Thanks Shadow.
Meystang
Sep 25, 2015 04:05 PM
jessicarabbit
Sep 25, 2015 12:41 PM
pimp2303
Sep 17, 2015 08:45 PM
TfcCDR
Sep 14, 2015 12:08 PM
Wombatnation
Sep 13, 2015 09:16 PM
