thermostat?
Old Oct 9, 2005 | 05:25 PM
cviteri's Avatar
cviteri
Default thermostat?
does my 96 stang has a thermostat?
Old Oct 9, 2005 | 05:29 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: thermostat?
yeah, it's in the housing that has a neck on it right in front of the engine on top.....behind the fan
look for where the big rad hose goes to....
Old Oct 9, 2005 | 05:32 PM
cviteri's Avatar
cviteri
yeah i did i open that part and it doesnt have anything is that y my car is overheating?
Old Oct 9, 2005 | 05:53 PM
PipsBlackStang's Avatar
PipsBlackStang
The thermostat opens to allow coolant into the engine. The engine first heats up and then when it reachs some temp. the thermostat will open and allow the coolant to cool the engine. If there was no thermostat then I would think It would always be open. If you start your car and let it sit for a while and then feel the radiator hose it should be hot, telling you the stat opened. Not sure about if you dont have one, but I would def. get one if you dont have one.
Old Oct 9, 2005 | 06:51 PM
03YellowPony's Avatar
03YellowPony
Some ppl take them out thinking the engine will run cooler. This is not the case. The thermostat is needed to bring the engine up to operating temp quicker. Some of your emissions gear is keyed to come on at a certain temp. About 192 degrees. Install a 195 thermostat. It's stock temp. If you have mods, like a Diablo tune, you can go with a 185 degree t-stat. I HIGHLY recommend Stant's SuperStat. It's more reliable and heavy duty.
Old Oct 9, 2005 | 07:16 PM
vfast's Avatar
vfast
I ♥ Acer
I recommend only 1 ..mr gasket hipo...it is balanced and have a trickle hole to prevent the air lock fords are famous for
Nick Oliver
Oct 17, 2018 04:22 AM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Wesley1995
Aug 30, 2015 02:01 PM
