Running Hot!
Old Jul 6, 2014 | 09:00 PM
spice1's Avatar
spice1
Default Running Hot!
I have a 1997 Cobra SVT with a newly rebuilt engine balanced and blue printed. Problem is now it is running hot, about 230 degrees. They say it's fine but I feel it's still too hot. Any ideas? What does everyone else think?
Old Jul 7, 2014 | 08:52 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Welcome to the forum, a fresh motor will run alittle hotter till broken in, but there are things to check for added peace of mind.
Is the radiator clean, inside and out, is the fan working properly, are the hose's old and weak and maybe collapsing ? Waterpump and T-stat should be new from rebuild.
230' is on the hot side, but not worrisome with a fresh motor. Break it in, then watch the temps drop.
Old Jul 10, 2014 | 02:42 PM
zacharoni16's Avatar
zacharoni16
I agree with 88 orangepeel, 230 is hot, but not alarmingly hot for a freshly built motor. All the tolerances are still tight and clearances are getting broken in. Once they do the friction will reduce and the temperature should drop.
Check the oil level/type of oil just in case. I assume all the hoses and radiator have been checked since the engine was rebuilt?
Old Jul 11, 2014 | 05:52 PM
spice1's Avatar
spice1
Default Re: Running Hot!
Thanks for the idea's and suggestions. Radiator is new, better thermostat just arrived today.
Do you feel a 2 core or 4 core radiator is best. I also have a single fan. Been burped, hoses are good.
First time playing with the Cobra, so not sure what is right for this car...
PS- Where to fid door panels?
Thanks
Old Jul 12, 2014 | 06:43 AM
88 orangepeel notch
2 core is fine, single fan is fine, as long as they're working like they should.
Check out "Latemodel Restoration" website, they may have your door panels.
1TUFF302
Nov 5, 2015 04:02 PM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
96stang3.8
Sep 10, 2015 06:42 AM
