Sponsored by:
Sponsored by: DashLynx
98 mustang dome light issues
Old 01-10-2015, 07:52 PM
Arstangs
Arstangs's Avatar
Default 98 mustang dome light issues
ok i have a 98 GT the dome light or map light do not work. door chimes work, does not come on with headlight switch either fuse in the fuse box is good and everything else works besides the door locks and trunk button. its not a big deal i just would like for it to work lol sucks at night
Arstangs is offline
Old 01-10-2015, 10:12 PM
yourmom6990
yourmom6990's Avatar
Maybe the bulb?
yourmom6990 is offline
Old 01-10-2015, 10:24 PM
Arstangs
Arstangs's Avatar
all three are good lol
Arstangs is offline
Old 01-11-2015, 08:24 AM
cruisin5268d
cruisin5268d's Avatar
If you're positive the bulb and fuses are good then it's time to look into the trickier things. Check all the connectors and the wiring. Some sort of switch / relay could have gone bad as well.
cruisin5268d is offline
Old 01-13-2015, 08:34 PM
v6power88
v6power88's Avatar
Get to the wiring in the dome light, 3 wires, black and white=ground, black =always hot? And green and red= positive at switch? Or other way around. anyways, test to make sure all wires function properly, if so just rewire positive wire to either a door trigger or your own toggle switch and bam, dome light works, if not, the dome light fixture might be damaged.
v6power88 is offline
Gregz
10-18-2022 03:52 PM
djbigskrilla
09-20-2022 01:04 AM
Diode Dynamics
28
05-26-2022 12:02 PM
mweiland
08-13-2015 05:11 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 98 mustang dome light issues
