Need help! Thumping from rear left tire!
Old 02-03-2018, 12:01 PM
Humanrekingball
Humanrekingball's Avatar
Default Need help! Thumping from rear left tire!
I have a 2001 Mustang Gt. She has about 112,000 miles. The issue I am having is a thumping noise. Almost like a flat but not quite as violent. It also increases/decreases with tire speed. It has brand new tires and rims. It doesn’t always make the noise sometimes it’s non-existent sometimes it’s non-stop. Do you guys think it could be wheel bearing/hubs or suspension related?
Thank you guys for the help,
Kyle
Humanrekingball is offline
Old 02-03-2018, 12:04 PM
Humanrekingball
Kyle
On that note I have also jacked the car up and tried to move the tire. Everything seems solid. Shock absorbers seem straight. Nothing looks out of the ordinary. They guy before be supposedly re-did the rear end. I don’t know how true that is. But it does look like someone took a sledge hammer to the end of the hub where the rim sits on. It’s kind of mushroomed out. We had to file it down the make the rim for up on it. However it has been working so far. None of the lug nuts have come loose. The only problem is that noise
Old 02-03-2018, 12:45 PM
Z28KLR
Z28KLR's Avatar
Was the noise present prior to installing the new wheels?
Happens when going straight, when turning right or left, or just whenever it feels like?
Z28KLR is offline
Old 02-04-2018, 01:17 PM
slipperman
slipperman's Avatar
The area the rim interfaces with the hub is critical.
If the hub face is not flat and true (no axial run-out), the rim will not set perpendicular to the axle center line.
The displacement is exaggerated out at the wheel edge creating a wobble as the wheel rolls.
You may need to replace the axle, which is really easier to do than you might imagine.
slipperman is offline
Old 02-04-2018, 08:42 PM
Humanrekingball
It just happens whenever it feels like. Sometimes it doesn’t do it at all. Sometimes is does it all the time.
Humanrekingball
That makes a lot of sense thank you very much for the input!
JUSTA2V_04
11-25-2015 05:40 PM
robinson209
02-03-2009 05:06 PM
Sherwood06GT
02-08-2008 10:58 AM
Kens440
09-22-2007 03:25 PM
99gtstang
09-16-2006 03:42 AM
Quick Reply: Need help! Thumping from rear left tire!
