Need help with a 2007 Mustang V6 Lights
Old Jul 28, 2018 | 11:47 PM
philipja's Avatar
philipja
Default Need help with a 2007 Mustang V6 Lights
Hey
I recently bought a 2007 Mustang V6 and the previous owner had added on GT fogs lights to the grill. All the wiring is still in place but the one wire which isn't connected to anything is the power cable. The previous owner said his son had attached it directly to the battery and hadn't gotten around to adding it to the Fuse Box.
Hoping to hear someone's opinion on how I should go about powering the lights and if the recommendation is attaching it to the Fuse Box, which Fuse/relay location I should attach it to.
Thank you guys!
Old Jul 30, 2018 | 03:46 AM
08'MustangDude's Avatar
08'MustangDude
Banned
You can power the fogs with anything, through a relay, battery or the fuse/relay
center.
The RED wire at the bottom center, is power for my Fogs. Mine came
with a harness, fused with a relay. The white wire is the Halos, that come on
with the car.
There are plenty of power taps like that in there. Then, you run your relay
trigger to a switch inside the car, or you can buy the light switch that has
the PULL for fog lamps, and wire to that.
My fogs have 65-watt bulbs, and I have them come on with the hi-beams
for now. They will soon have 75-watt hids.
jhawkr
Oct 30, 2015 01:55 PM
locorider21
Nov 10, 2008 06:02 PM
luvs_stangs
Aug 31, 2008 10:24 PM
creekrat
Sep 7, 2007 06:40 AM
2nd II None
Sep 5, 2006 12:33 AM
