Crank no start
Old Jan 2, 2019 | 06:17 PM
Kyle Yount's Avatar
Kyle Yount
Default Crank no start
2000 3.8l will crank but will not start. Fuel pressure is 45, has spark, IAT and coolant temp sensor both reading as should. When i am cranking the engine and press the throttle down the engine feels like it gets to much gas and cranks hard then when I let the throttle back up it cranks normal again.
Old Jan 2, 2019 | 06:38 PM
Urambo Tauro's Avatar
Urambo Tauro
Welcome!
Check the battery first. The PCM can't do its thing if the voltage drops too low while cranking. Even if that doesn't end up being the problem, you gotta rule out that battery before you end up on a wild goose chase.
nba1341
Nov 5, 2019 03:25 PM
coreyc7771
Jun 11, 2013 07:06 AM
2000GTUK
Jul 11, 2010 01:28 PM
steve58
Apr 9, 2009 07:00 AM
jcman0218
SVT Forums
Sep 17, 2008 12:30 AM
