Pinion flange
Old Dec 27, 2019 | 10:52 AM
Kevin Gentry's Avatar
Kevin Gentry
Default Pinion flange
Hello guys, I have a 06 mustang v6...having trouble with the pinion seal leaking, after three attempts of changing the seal I realized the flange has some scratches so I grabbed one for the local junkyard. Thinking all 7.5 rearend are the same I took one from a 98 v6...it’s smaller and the driveshaft doesn’t bolt to it. What’s the deal? My biggest concern is I swamp them real quick not wanting lose to much gear oil....are the splines the same? It seem to slide on okay. Thanks
Old Dec 27, 2019 | 09:32 PM
JimC's Avatar
Super Moderator
You can't just assume "and 7.5 is a 7.5" and think that parts will fit. As you found out, the driveshaft bolt pattern and size are different. You have to use the parts for your car.
mcssboy13
Nov 29, 2014 07:50 AM
Synyster06Gates
May 25, 2012 01:23 AM
chays446
Jun 10, 2009 05:38 AM
brock_07
13
Oct 29, 2008 10:58 AM
Ketis
Nov 26, 2007 09:00 AM
