Spark Plug Removal
Old Feb 17, 2020 | 03:23 PM
skin5050's Avatar
skin5050
Default Spark Plug Removal
I want to install new spark plugs . As you can see from the pics , I was able to completely remove one, but the other one is being stubborn and won’t come out . The metal thread is completely out which is great, but the actual spark plug is still intact. I used needle nose pliers to try and pull it out and even sprayed Wd40 to help loosen it. No dice. Any thoughts? I have a 2006 mustang GT. Thanks!!
Old Feb 18, 2020 | 12:27 PM
Derf00's Avatar
Derf00
Gentleman's Relish
There are no pics to see but, you have a few options.
https://www.freedomracing.com/broken...iABEgLevfD_BwE
https://www.amazon.com/Lisle-65700-Broken-Remover-Engine/dp/B00SQ4FSN6?source=ps-sl-shoppingads-lpcontext&psc=1 https://www.amazon.com/Lisle-65700-Broken-Remover-Engine/dp/B00SQ4FSN6?source=ps-sl-shoppingads-lpcontext&psc=1
If you haven't already tried to remove the rest, here's the ford recommended method (TSB) on how to remove them to reduce the potential for breakage.
https://www.aa1car.com/library/ford_tsb_08-7-6.pdf
After you get them out DO NOT replace them with the same garbage plug. You can either go with Champion 1 piece plugs PN 7989 or Ford's updated plug for the Mustang (Can't think of the part number right now). I don't trust the ford part number as it still appears to be a 2-piece plug. The only thing they did was add a couple of tack welds to crimp area.
I and most others went with the Champion plugs. I've had them in my car for over 80K miles now (replaced the OEM's at 10K back in 2009). I'm on my second set of Champions right now. Ford only recently released the updated plugs (last two years?) so who knows about the long term reliability with them.
Old Feb 20, 2020 | 09:33 AM
skin5050's Avatar
skin5050
Thanks a million. Would a pair of long needle nose pliers work instead? Or something like the pic below?
Old Feb 20, 2020 | 12:50 PM
Derf00's Avatar
Derf00
Gentleman's Relish
You can try but the tools were made for a reason. If the carbon on the spark plug tip is really thick, pliers won't get the pieces out. It cements the spark plug body to the head.
You can always buy the tool, use it, then resell it for what you paid for on e-bay or craigslist. You can also check if your local auto parts store has one they can rent to you.
Old Feb 20, 2020 | 01:44 PM
skin5050's Avatar
skin5050
Thanks. I just ordered the kit. Last question. Of the plugs I removed, there was a considerable amount of build up. Whats the best way to clean/remove all of that before installing the new plugs?
Old Feb 21, 2020 | 07:38 AM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
I printed that service bulletin out and keep it with the shop manual for my Navigator. Thank you for posting that up.
Good stuff.
Old Feb 21, 2020 | 12:19 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Build up where?
Just use top tier fuel like Cheveron or Shell or the like. The detergents will help clean up the interior of the cylinder. You can also add a fuel system cleaner to the tank and/or seafoam (follow instructions).
Old Feb 21, 2020 | 12:20 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Good stuff.
Quite welcome Fastback. If you replace the ford 2-piece plugs with the Champion 7989 you won't have to worry about that issue i the future
Art161
Sep 20, 2010 08:34 AM
thuxel
Dec 28, 2008 10:28 AM
loots06
Sep 15, 2008 11:17 PM
justingt
18
Sep 4, 2006 01:21 AM
rx7pl
Sep 20, 2005 03:18 PM
