Door lock replacement
Old Nov 23, 2021 | 08:42 AM
abcdefghii's Avatar
abcdefghii
Default Door lock replacement
I am trying to figure out which door lock cylinder I need for my 2004. While the car appears to have the PATS installed (theft light blinking) I do not have a remote, the only key I have, while has the large plastic end, is not the a Ford key and does not appear to have the small rectangular shape on the end indicative of the chip inside.
The key I have starts the car fine, as well as opens the trunk without issue. But, there is no drivers door lock cylinder, it's just a hole where one should be.
I'm not sure how the, what appears to be, non PATS key has no issue starting the car. But, also not sure which lock I should get for the drivers door. I don't care if I end up with different keys, just want to lock the door!
Can I use a non PATS cylinder and call it done? Or are the mechanisms different between non PATS and PATS?
Thanks.
Old Nov 23, 2021 | 10:37 AM
imp's Avatar
imp
Thanks.
The door lock cylinder is strictly a mechanical part to allow locking and unlocking the door should power door locks fail. Not connected to PATS in any way, I don't believe.
Old Nov 23, 2021 | 11:45 AM
abcdefghii's Avatar
abcdefghii
Excellent, that's what I'd been hoping. Kept finding things listed as with/without PATS which makes life confusing.
Old Nov 29, 2021 | 03:35 PM
abcdefghii's Avatar
abcdefghii
So, does anyone know how to make the lock cylinder stay in the door? The parts arrived today, slotted into the door, connected the rod, tried locking / unlocking with the key, great. But, the lock cylinder just flops out of the door with as far as I can tell, no visible way to physically secure it to the door itself.
Old Nov 29, 2021 | 03:39 PM
abcdefghii's Avatar
abcdefghii
Looks like I can't edit my post, but it appears that I am missing the clip that slots over on the inside of the door. What a pain. Going to guess nowhere local will have those either.
thewalesaver
Oct 26, 2010 07:26 PM
chilledfresh
Apr 2, 2009 03:18 AM
con65stang
Mar 7, 2008 09:44 PM
supermanx68
Mar 27, 2007 03:52 PM
roblarss
Jan 10, 2007 04:13 AM
