Having trouble with puddle light install.
Old Jan 27, 2022 | 12:25 AM
Jono27's Avatar
Jono27
Default Having trouble with puddle light install.
I have a 2007 gt and installed the puddle lights. Picked up power from pass. A-pillar and they work fine. My problem is now with the key fob, it doesn’t work when the lights are on. I can unlock the driver door fine, but that turns them on and the fob is locked persay. If I unplug the lights, the fobs work perfectly. I called the company that sold them and they are confused as well. Need some advice, please.
Old Jan 27, 2022 | 12:35 PM
Derf00's Avatar
Derf00
Gentleman's Relish
What does the power wire you pulled power from in the A-pill run? If the circuit is power or resistance sensitive it could cause problems. If it thinks the circuit is open or shorted from an excessive current draw or less resistance, t may cut/reduce power. A lot of security circuits work like this. Might need to find a different power source.
Old Jan 27, 2022 | 06:36 PM
Jono27's Avatar
Jono27
Derf00,
the plug in the A-pillar goes up to the dome lights. That’s what the instructions say to tap into, but it’s causing the remote not to work. Someone else posted the same issue back in 2013 but never posted any solutions.
sargentmajord
Nov 7, 2019 03:12 AM
Zoranan
V6 General Discussion
Sep 30, 2012 06:30 AM
Shanepa
13
Aug 11, 2010 09:47 AM
GibMax
Apr 13, 2010 09:52 PM
Sxynerd
Apr 23, 2007 03:11 PM
