Sponsored by:
Sponsored by: DashLynx
Wondering about throttle bodies
Old 11-28-2005, 02:46 AM
stangman2354
stangman2354's Avatar
Default Wondering about throttle bodies
I was wondering if i should get a throttle body after i get my intake and exhaust system and if it will give that much of an increase in power and what kind
stangman2354 is offline
Old 11-28-2005, 03:40 AM
03YellowPony
03YellowPony's Avatar
Default RE: Wondering about throttle bodies
ORIGINAL: stangman2354
If you do, you will have to port the intake opening to match the new T/B. Otherwise, you can actually lose power.
03YellowPony is offline
Old 11-28-2005, 10:59 AM
Chopper
Chopper's Avatar
Get a better plenum when you get the T/B.A better flowing plenum gives bigger gains than a bigger T/B.MM&FF did a test(Apr 04)on a near stock 02 GT that gave a 10 HP and 10 FT/LBS of torque.A 75mm Accufab T/B was added and and the numbers went up by 2 HP and 3 FT/LBS of torque.A bigger T/B without a bigger plenum opening would cause turbulence in the upper intake and probably cost you a couple of horses.
Chopper is offline
Old 11-28-2005, 06:04 PM
92hatchLX
92hatchLX's Avatar
Get the intake and yes get a bigger throttle body AFTER the intake.
92hatchLX is offline
Old 11-29-2005, 01:17 AM
88BlueGT
88BlueGT's Avatar
Yea, there are alot of reputable companies who make throttle bodies (accufab, bbk, etc. etc. etc.)
88BlueGT is offline
Old 11-29-2005, 11:40 AM
nitrous_bob
nitrous_bob's Avatar
i wouldn't bother...you won't benefit until heads are swapped.
maybe .005 but not even worth getting your hands dirty.
nitrous_bob is offline
Old 12-01-2005, 12:21 AM
moosedan
moosedan's Avatar
sure he would benefit. why would you say that? are you telling me the stock tb would be the same result if he used a aftermarker tb? tsk tsk tsk. yes, get the bigger tb. i was putting out 300+ with stock heads and that would included a bigger tb.
moosedan is offline
Jb145700
08-21-2022 06:37 AM
GimpyHSHS
09-18-2015 12:27 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Webster454
09-07-2015 04:59 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Wondering about throttle bodies
