drivers window help
Old Jan 11, 2006 | 03:37 AM
posnick's Avatar
posnick
Default drivers window help
my drivers window rocks back and forth. there is the main vertical bar that the window slides up and down on. how do i remove this bar? the plastic guides that hold the window from rocking are broken and need replacing. the only way i can see to do this is to remove the whole window and the main bar. HELP!!!!
Old Jan 11, 2006 | 08:35 PM
posnick's Avatar
posnick
Default RE: drivers window help
somebody must have an idea
Old Jan 11, 2006 | 10:41 PM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
That bar is part of the regulator assembly I believe, it's been a while since I tore a mustang door apart. It is most likely riveted onto the door. Pull the panel and take a look. Are you sure thats the part thats broken?
Old Jan 11, 2006 | 11:53 PM
posnick's Avatar
posnick
its the two plastic spacers that goes on the upper and lower adjustment for side to side adjustment thats broken. thing is though it looks like i have to remove the window in order to get the vertical bar out and i cant figure out how to remove the window. it figures, i dissasemble the whole car but cant do this
Old Jan 12, 2006 | 12:19 AM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
I *think* the glass is riveted to either a channel or piece of flat stock on the regulator. You will see it when you pull the panel.
Knock the center pin out of the rivets then drill the head off. There may be one or two 10 or 11mm bolts that hold the side "glass runs" to the door, remove them so you can get the glass in and out easier.
Old Jan 13, 2006 | 02:11 AM
posnick's Avatar
posnick
thanz grimace. thats exactly what i needed. appreciate the help!
Old Jan 13, 2006 | 09:35 AM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
ORIGINAL: posnick
No problem man. If you need anything just ask.
Good luck!
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
TCStangerv6
Oct 11, 2015 05:57 PM
guitarman376
Sep 30, 2015 05:54 PM
