Damned thing wont start, possibly ign. solinoid or starter?
Old Jan 25, 2006 | 01:59 AM
nelson95's Avatar
nelson95
Default RE: Damned thing wont start, possibly ign. solinoid or starter?
my car did it before scared the bageesisss out of me it was just a loose battery cable
Old Jan 25, 2006 | 06:58 PM
Dearborn5.0's Avatar
Dearborn5.0
Question for the guys who replaced the neg battery cable...
where did you get your replacement unit?
You know, the one with the little ground wire attached to the terminal for the computer ground?
Murrays has generic replacement neg battery cables. No little ground wire for the computer.
Old Dec 3, 2007 | 11:16 AM
gogata's Avatar
gogata
Could a bad starter bind the engine and not allow it to be barred over?
Old Dec 3, 2007 | 08:45 PM
patrickfxck's Avatar
patrickfxck
put the key in, turn it on, throw it in neutral, make a connection between the two bolts on the starter cylanoid, cheap 13 dollar fix if its the problem.
Old Dec 3, 2007 | 11:18 PM
gogata's Avatar
gogata
At first i thought it was the solenoid also. I jumped the solenoid but the engine still would roll over. I can't even bar the engine over. Is there anything externally that could cause the engine to seize.
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
Itstbrown
Aug 9, 2015 03:49 AM
