GASP! A POP AT 5,000 RPM
So I was side to side with a BMW... And we were both runing hard, that is until I had to slow down cuz I heard a pop in the engine (and it kinda stalled a little bit too)[X(]. I think it might just be my carb not adjusted right, but if anyone has any ideas, please speak.
RE: GASP! A POP AT 5,000 RPM
The reson why that would happen to me is because of fuel starvation. It happens to my truck all the time when I am under 1/8th tank and nail it hard. It happens when I am at 5450rpms ready to shift and it pops and hesitates. I take care of those problems by keeping the tank higher than 1/8th and a Diablo tuner to adjust for fuel at higher rpms.
Try larger jets to see if that helps. What carb are you running right now, also what ignition system?
-Neo-
-Neo-
My friend's carbed Mustang was doing that in higher gears up in the higher RPM range. It turned out to be a combo of the carb floats adjusted too low and not enough fuel pump. The engine goes lean and miss fires making a popping sound and a feel like a hesitation or stall. I would start in these areas.
