nitto's in rain?
nitto's in rain?
It's time to get new tires, and I was thinkin of spending the money on nitto's..... my question is, do they drive any different in the rain than normal stock tires? better or worse? new tires and LCA's were gonna be my first mods for good traction.... and are LCA's as easy as a CAI install, or does a shop need to do it? thanks
RE: nitto's in rain?
If you are talking about the 555 series, they are a summer tire, will suck *** in the rain. The lca install, it depends on if you are going adjustable or not. The non adjustables are just a drop-in, the adjustables, you need to know about pinion angle and all that happy stuff.
what exactly do adjustable LCA's adjust? I know they are a bit more expensive than the nonadjustable ones... thx for the input on the nittos..... ill probably just get the same tires i have now
The ADJ.LCA is needed if you have an after market driveshaft... it helps to adjust the angle of the pinion for less vibration ... I have adjustable lowers and solid uppers .... you can either get adjustable uppers or lowers.. but just choose one.. I preffer the adj LCA thanks to crazy all .. the adj. upers is just hard to reach ...
Im not really sure if the adj. is used for something else other than adjusting your driveshafts angle...
about the nitto's im also looking forward into getting the 555's .... but its not time yet.. 15,000 kms are left... hehe.. after that i'd get them and fix them for summer only.... our winter is dry but cold... and it sucks when it rains because its hard to drive like i normally do .. i'll have to slow down..
ORIGINAL: Archion
ORIGINAL: Archion
ORIGINAL: scramblr
I have to disagree on this one. I was running stock BFGs before going with 555s and the difference is night and day. City driving allowed me to take turns at higher speeds (not crazy driving) than that BFGs and my back end would stay planted. On the autobahns I wouldn't do over 90-100mph with the BFGs because the front wheels really dug into the water. With the 555s I was running 120-130mphs in the rain with full confidence. Yes, they are listed as high performance summer tires but built for wet roads as well. They state "summer" so that some butthead doesn't try to run them in the winter.
ORIGINAL: Archion
ORIGINAL: therobman7
Ok, now im really confused.... not sure i drive as crazy as you guys, so maybe the nittos will be ok... plus, im in cali, so we dont see a whole lotta rain anyway
ORIGINAL: scramblr
ORIGINAL: Archion
ORIGINAL: saud alzaabi
What about In high humidity temp ?
and where Can I find them tires ? cheap .. in good price.. would they fit my 18' fanblades ?
arigatooooo
arigatooooo
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
09-08-2015 11:50 AM
