Purchased the Saleen SC today!
Old 07-21-2007, 10:09 AM
  #41
sactown
sactown's Avatar
Default RE: Purchased the Saleen SC today!
I have read some good reviews on that CAI, I just have not seen anyone running. I will look into it.
sactown is offline
Old 07-21-2007, 01:31 PM
  #42
phatphil
phatphil's Avatar
No clearance issues with the E tube.
phatphil is offline
Old 07-21-2007, 01:32 PM
  #43
phatphil
phatphil's Avatar
I believe that is the E tube and no you won't have any clearance issues with it.
phatphil is offline
Old 07-21-2007, 01:42 PM
  #44
TPony
TPony's Avatar
great combo there my friend.
TPony is offline
Old 07-21-2007, 03:58 PM
  #45
cheftjpeck
cheftjpeck's Avatar
ORIGINAL: zoomerman46
Here is my answer to the CAI question. No hood interference with the WMSracing cai and their 95mm tube,39lb injectors,8lb pulley, dyno'd at 430 rwhp 425 torque. I am very happy with this combo.
[IMG]local://upfiles/15603/292F0B40B19244E18A0475AB809095FA.jpg[/IMG]
zoomer...i love the look of your setup..one quick question...where is the MAF sensor on that beast?? is the sensor a 90mm+ sensor??
cheftjpeck is offline
Old 07-22-2007, 09:43 AM
  #46
zoomerman46
zoomerman46's Avatar
The sensor is located in the short aluminium tube that comes with theWMS Cai.It uses the the stock mas air sensor.It's machined to fit the sensor and use the same screws to attach it to the tube.If you choose to go this route make sure you order with the larger tube. You can use this same set up for n/a motors but it used the 80mm tube.The 80will peg out the mass air meter at 5.0 volts long before you get to 6000rpm's if you go the Saleen route.The install requires you to relocate the overflow tank and splice the maf wiring to lengthen them but no big deal.I have never had a problem with the cai as a n/a motor or blown.
zoomerman46 is offline
Old 07-22-2007, 03:45 PM
  #47
cheftjpeck
cheftjpeck's Avatar
cool, thanks...yeah already went the saleen route...I just like the look of your your CAI...thx again
Old 07-22-2007, 06:03 PM
  #48
sactown
sactown's Avatar
This may sound stupid but is the "E" tube the saleen tube?
sactown is offline
Old 07-22-2007, 07:36 PM
  #49
cheftjpeck
cheftjpeck's Avatar
ORIGINAL: sactown
yes, saleen extreme inlet= "E" tube
Old 07-22-2007, 08:28 PM
  #50
QatarStang
QatarStang's Avatar
Congratulations on the purchase
QatarStang is offline
lincolnshibuya
12-08-2015 04:37 PM
jrrhd73must
10-02-2015 09:17 PM
mungodrums
09-28-2015 10:54 PM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Purchased the Saleen SC today!
