Ripping out the BBK headers...help!
I'm at a stand still right now. After managing to get the top bolts out of the headers, the taking the h-pipes off with the starter. I'm baffeled how to get the steering linkage apart so I can get the engine mount ears off. Also I was just going to use a big block of wood to wedge under the tranny to hold it up so I can jack it 1-1/2", that a kosher thing to do? Any insight how to either get the header out w/out taking out the steering linkage or how to get the linkage off w/out busting that little clip in it?
RE: Ripping out the BBK headers...help!
Remove the lower bolt from the steering shaft coupler at the power steering rack. Then remove the top bolt attaching the rack to the frame on the driver’s side and loosen the same bolt on the passenger side. Slide the rack forward on the driver’s side approximately 1” and remove steering shaft coupler from the rack.
Use that wood to support/jack up the engine not the tranny. 1 1/2 inches or so will allow you to totally remove the mounts.
There are 2 bolts on the bottom of the steering column. Remove the upper one. After that you really gotta give it a rap with something to shorten it enough to get it off. This was a real PITA when I did mine. I had to use a long crow bar and hit it with a hammer to shorten it so it would slide off.
To get it back on, it was just as much of a PITA. I even sprayed oil on the slip joint in the center of the shaft, but it still binds tight for some reason. The best way to lengthen it again when you need to put it back on is to slide an open end wrench down over the lower part of the shaft and hit it with a hammer to lengthen it. Find the right size open end wrench that will just fit around the shaft but not around the lower collar.
ORIGINAL: kcmarti
Remove the lower bolt from the steering shaft coupler at the power steering rack. Then remove the bottom bolt attaching the rack to the frame on the driver’s side and loosen the same bolt on the passenger side. Slide the rack forward on the driver’s side approximately 1” and remove steering shaft coupler from the rack.
Use that wood to support/jack up the engine bot the tranny. 1 1/2 inches or so will allow you to totally remove the mounts.
Two other things I could suggest for the motor mounts is a super long socket extension for tightening from up top and a set of ratcheting wrenchs? They are open on one end and have aratchet on the other. There's probably a better name for them but they made the job much easier.
Thanks guys worked like a charm!! I left the driver side mount in place and the header just fell right out. The passanger side was a different story though. Ran out of daylight so I'm going to clean up the mess from the exhaust leaks tomorrow. From the looks of things there were leaks all over on both driver and passenger sides. What kind of makes me angry is that the diameter of the heads are different than on the headers themselves. The exhaust ports off the block are bigger volume wise compared to the headers...kind of a haphazard design if you ask me. In addition to that, the gasket material that came with the headers in pretty substandard itself...so just a matter of time before they were gonna go.
Again though, thanks guys for the insight. Slapping the stock headers on tomorrow morning
Stock headers are back on and no leaks!!!!
I'm tired of the aftermarket exhaust scene for the most part. Nothing ever fits "quite-right". And honestly I like the sound of stock headers, h-pipe with the STEEDA axle-backs much better. Just personal preference really.
ORIGINAL: SirKnightTG
Why are you going back to the stocks?
Luke9222
10-22-2015 11:55 PM
