Cam Questions
I have the comp stage 2 thumpr cams and I got some decent power from them along with a pretty sweet sound
http://www.youtube.com/watch?v=uPFz_0QtkJU
Those who are getting BBR cams I hope they're billet and not re-grinds. Re-grinds require shims which is just a really crappy way to go about it. If you're going to do it, do it right. You don't want something as important as a valve-train to let go due to a "hacky" implementation. That's all a re-grind is is a cheap hack.
I'd never use a re-grind in a million years.
For me, I'd go either Comp or FRPP. As a matter of fact, I'm most likely going Comp Cams ***** Thumpr. Although I'm still tempted by the Hot Rods due to the Ford Racing name and they're a little easier to install since they don't need phaser mods.
Last edited by SirKnightTG; 07-20-2009 at 07:08 PM. Reason: Spelling is not my strong point. ;)
The re-grinds do have the advantage of being cheaper. People have been doing them for a long time due to that. But they have also been using buckets of bondo to "fix" bodies on the cheap too.
It just doesn't feel right to me to have to add metal and re-cut a cam to be something it wasn't originally built to be and then having to shim up the valve-train to make the thing even work right. It's like a "bondo fix" for cams. But I guess if someone doesn't mind having a "franken-motor" to save a few bucks...
That right there shows there's something fishy about re-grinds. That's a red flag to me.
Good to hear you're getting the billet.
the only cam you dont want as a regrind is a stage II or stage III.
The BBR cams do have a wicked idle. Even the stage 1 sounds killer. I think BBR was the first guys to get the S197 to have an old school lope idle. The video of a yellow GT on youtube with BBR Stg 2 was there long before Hot Rods and Thumprs.
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
