twin turbo kit
Speaking of turbo lag, is it possible that any of the linked vendors could make compound turbo set-ups for each bank?
What I mean is basically you have 4 turbos. on one bank, you have a small turbo for instant little-lag or even no-lag off-the-line acceleration, and then once you hit higher RPMs, you have the larger turbo which should be spooled up to speed pumping in some serious HP, the 700 HP range.
You have the same compound turbo set-up for the other bank, and this is how you have 4 turbos.
i spoke with someone at hellion yesterday and he said that they are just starting work on a twin turbo kit for the 2011 gt and that if they did make one for my year that they will use this one to start from and it could be about a year before they sell it. which is fine because that is how long it will be before my car is ready for the installation.
i will probably just end up going with a single turbo if you guys are saying that twin doesnt really work well with our motor.
thanks for the help and if anyone has more input please tell
I loved my turbo. Street driving was fun, but the TS blower is the best IMO for a DD street car.
hey earl, how much power are you making with your setup, because hellion told me with the t66 i could make up to 700 whp. if its not much of a difference then i would probably just put the extra money it would cost to twin turbo it into building the motor.
If you keep a stock engine, it will blow before you get to 700 horses.
After 10psi (which equals to roughly 500hp at the crank) on these engines, you're on burrowed time.
Although I am not an expert in FI, the twin turbo concept is trying to avoid lag and getting torque down low.
That's why you see a smaller one in some applications... It comes on first and right away while the other one takes you to max power across the grid.
It takes some good engineering to make it work perfectly but it pays off in the end.
For DD on any V8, a Roots style blower seems to be the most user friendly like Simon says.
Smaller engines (like 4 bangers etc...) prefer Turbos though...
It won't be so bad. You won't feel too deprived. When my car was street driven, I was never into light to light racing or street racing period. The 67mm single turbo was quicker in response than the Procharger that was on the car before going turbo. The 67mm is good for about 650 rear wheel with the appropriate build support. Car has the 76mm now and that definitely did lag on the street, but is irrelevant now since car has been rebuilt for dragracing only and any lag is functionally eliminated.
Got to be careful with these single turbos though. The monster torque they generate can eat up your internals, transmission..whatever.
pic of car launching with the 76mm, with the old build.....no lag. See the torque twisting and rippling the huge Hoosiers. The rims are drilled into the rubber and you have to build up the rear end to avoid snapping like a toothpic. After shredding a trutrac, we spooled the 9 inch rear
Earl
jwog666
12-27-2021 08:09 PM
