06 GT, towed, battery?? Alt??
Old 10-16-2018, 07:15 PM
427Impala
427Impala's Avatar
Default 06 GT, towed, battery?? Alt??
2006 GT conv (if that matters, 83K miles, very nice shape), driving home, after 2 miles the 'volt gauge' needle bounces some, heads to the low side, ABS, Trac Cont lights come on, red battery comes on, radio turns itself off.
I stopped by a friends house to get towed home to be safe.
Once home, it starts with Jump Pak, only 13.2 v across terminals.
Thoughts?? I will borrow a friends code tool, but if anyone has thoughts now, I am open. Yes this dang thing has the battery drain issue, but I keep a Battery Tender on it.
Thnx
427Impala is offline
Old 10-16-2018, 09:09 PM
jz
jz's Avatar
If it happened while driving, I would lean towards the alternator being the issue. How old is the battery? Running a battery dead is a sure fire way to shorten the life span so depending on the age, you may want to consider a new battery. But most shops can do a load test on the battery and give you a yes or no for the battery health.
jz is offline
Old 10-17-2018, 12:32 AM
Dino Dino Bambino
Dino Dino Bambino's Avatar
Sounds like your alternator is failing. However you also need to solve the battery drain problem. The Shaker 500 ICE system is a common cause so if you have it, you might contemplate ditching it for another system.
Dino Dino Bambino is offline
Old 10-17-2018, 02:05 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Thnx
13.2 with the car running? If so, that with the wonky electrical show usually means alternator.
Derf00 is offline
probinator
10-06-2009 03:51 PM
LOUDexhaust
03-22-2009 08:59 AM
shadowgames81
01-13-2007 08:20 PM
Gilligans Hitch
03-26-2006 10:09 PM
ByPopularDemand
11-23-2005 12:00 AM
Quick Reply: 06 GT, towed, battery?? Alt??
