Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
mach handling
Old Nov 6, 2007 | 01:42 PM
  #31
HamMach1's Avatar
HamMach1
Default RE: mach handling
Get full exhuast... longtubes, midpipe, and catback
Get intake... JLT raim air (4" tubing FOR THE WIN!) http://jlttruecoldair.com/zencart/in...products_id=57
Also things like a Accufab throttle body and PHP intake spacer will do you good.
A shifter... MGW, Steeda Tri-ax... most LOVE the MGW
Those who own Mach's are very iffy about UDP's, therefore I'm going to spend that $100 or so on something else rather than worrying about the fuel pump getting ****ed... there hasn't been 100% proof but this is one time I will stick to the band wagon and not get UDPs.
Get a dyno tune from a reputable shop near you... that will allow you to get every bit of horsepower out of each mod. You will be seeing over 300rwhp with those.
Old Nov 6, 2007 | 01:44 PM
  #32
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
well if yall say dont then i wont.
Old Nov 6, 2007 | 05:48 PM
  #33
nikbait's Avatar
nikbait
I've heard that unless you really do some heavy mods on the mach engine that putting in a throttle body is pointless, is this true? Also, what is the JLT ram air intake, does that replace the shaker?
Old Nov 6, 2007 | 06:26 PM
  #34
jmac72187's Avatar
jmac72187
corner carver
The JLT ram air just replaced the filter and tubing that travels to the throttle body. It still retains the functionality of the shaker. The JLT cold air no longer uses the shaker.
Old Nov 6, 2007 | 06:56 PM
  #35
nikbait's Avatar
nikbait
Ok so the ram air still uses the shaker. Got it. What about throttle body? Does that have to be modded if you aren't planning any serious engine mods, or is the stock TB good enough.
Old Nov 6, 2007 | 08:15 PM
  #36
USMCrebel's Avatar
USMCrebel
and the ram air gives more power than the intake?
Old Nov 7, 2007 | 05:27 AM
  #37
jmac72187's Avatar
jmac72187
corner carver
The Cold air might make a difference of a few HP but I don't think it would be much of a difference. I just like the idea of a functional shaker.
Old Nov 7, 2007 | 07:45 AM
  #38
USMCrebel's Avatar
USMCrebel
i see where your coming from whats the point of havng it on there if your not going to use it.
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
mungodrums
Sep 28, 2015 10:54 PM
