Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
intake spacers
Old Feb 5, 2008 | 08:17 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: intake spacers
i say that on the registry the night you posted it. that thing is retarded big. looks like thats a worth while mod on any mustang....esp for $100
Old Feb 5, 2008 | 08:32 AM
RoyC's Avatar
RoyC
ORIGINAL: USMCrebel
3 inch spacers are more than $100.00.
Old Feb 5, 2008 | 08:35 AM
jmac72187's Avatar
jmac72187
corner carver
How much are the 3/8" spacers?
Old Feb 5, 2008 | 09:03 AM
USMCrebel's Avatar
USMCrebel
LOL roy, i saw where you said set him back 700, i was talking about something i would be able to use.
jmac,
from what i understand all the spacers are $100 shipped (i think that includes everything.)
Old Feb 5, 2008 | 09:29 AM
RoyC's Avatar
RoyC
ORIGINAL: USMCrebel
jmac,
You are correct.
Old Feb 5, 2008 | 09:32 AM
jmac72187's Avatar
jmac72187
corner carver
I will be hittin you up sometime this car season for a spacer Roy.
Old Feb 5, 2008 | 09:36 AM
RoyC's Avatar
RoyC
ORIGINAL: redv6pony
ORIGINAL: RoyC
Here is a link to a 3 inch spacer I made for Brandon Foley's NMRA Renegade Mustang. I can make spacers in any thickness (3/8 is standard). I also port intakes with awesome results for about half the price mentioned above. Nice meeting you guys!
http://www.mach1registry.org/forums/...ad.php?t=75329
eventhough hes new here on MF Roy is a VERY legit guy
roy which size is the typical good gain one?
For a Mach 1 I would say the standard 3/8 is best. Any thicker and the EGR tube is hard to re-install and the rubber around the shaker starts to rub the hood.Later if you decide to delete the EGR system I can set you up with another 3/8 spacer kit with extra long bolts so you can stack two. You will have to slot the holes in the rear shaker bracket so the shaker can be moved down some. For a Cobra with no EGR I wouldusethe biggest spacer that will fit under the hood.
Old Feb 5, 2008 | 09:37 AM
USMCrebel's Avatar
USMCrebel
here is a post from the M1R from a guy that tested them. THIS IS NOT MY POST, I AM JUST REGURGITATING IT.
The baseline dyno numbers were achieved with 3 pulls, and the results were a best of 285.9 RWHP and 295.6 RWTQ, both SAE corrected. The A/F ratio was a steady 12.5 throughout with a dip to 12.0 between 4,000 and 5,000 RPM’s. This RPM range also corresponds with the peak RWTQ numbers.
The spacer test numbers were achieved with 2 pulls, and the results were a best of 289.0 RWHP and 310.4 RWTQ. The A/F ratio was also a steady 12.5 for most of the pull, with a jump to 13.0 between 3,400-3,800 RPMS’s and a dip to 12.0 between 4,000-5000 RPM’s.
Overall the gains were 3.1 RWHP and 14.8 RWTQ. The RWTQ gains were highly welcomed, as the car seemed to have lost some low-end torque after the install of the high flow x and cat back.
Overall the installation takes anywhere from 30 minutes to an hour
depending on mechanical aptitude and experience. The shaker must be removed and it is highly recommended that the EGR assembly be removed as well, as this enables you to completely remove the upper intake. Others have tried installing the spacer without removing the EGR and this only allows you to lift the upper intake so far, causing you to slide the spacer and gasket in place. This leaves you to guess on whether or not it is properly aligned and in place. The kit comes with 5 intake bolts that are longer than the stock bolts. 2 bolts must be re-used, one that holds the throttle linkage mount and the other that is directly across from the throttle body. Simply remove the shaker/EGR valve, unbolt all 7 bolts from the intake spacer and lift the upper intake up and off. Place the spacer on top of the existing gasket and place the new gasket on top. Re-install in reverse order and there you have it.
While the Mach 1 review doesn’t like to subscribe to “butt-o-meter†results, the PHP spacer is definitely a seat of the pants mod. The Mach 1’s 32 Valve motor wakes up at 3,500 RPM and with the PHP spacer the car seems to pull harder from that point on and more low-end torque is definitely felt through the gears. No stalling issues arose from the installation of the spacer which seems to be common among other intake modifications.
Old Feb 6, 2008 | 02:58 AM
MACH5IVE's Avatar
MACH5IVE
Ill be ordering a 7/8 spacer from you as soon as i can Roy! Love your work and your monster of a project!
Old Feb 6, 2008 | 10:45 PM
Stone629's Avatar
Stone629
Is there a delete plate or something to use in order to do an EGR delete? Also, will it cause any issues with the CEL coming on? I would love toinstall a 7/8 spacer for max gain, but don't want to do it if it's too much headache.
Roy, I will be getting one from you asap too. I've heard good things about your workmanship.
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
