Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
annoying squeek
Old Apr 10, 2008 | 02:34 PM
lilengland08's Avatar
lilengland08
Default annoying squeek
Hi guys im new to the forum, and i have only owned my mach 1 for 3 weeks.
Until about 3 days ago my 04 mach 1 has been running perfectly fine, but now there is a squeek.
The squeek is now happening more and more, as it used to happen when the engine was warm.. The squeek happens at 2000-2300 rpms, but only when the car is underload (in gear). If i rev the engine to this level it does not happen. The squeek i believe is coming from the engine but i could be wrong.. Any suggestions guys?[/align]
Old Apr 10, 2008 | 03:01 PM
DesertMach's Avatar
DesertMach
Default RE: annoying squeek
You need a louder exhaust......... haha just kidding. can you be more specific about what type of squeak? like belt sounding, or could it be the infamous shaker squeak???
Edit: A4 or M5, maybe TOB?
Old Apr 10, 2008 | 03:30 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
oculd be tranny, shaker, belt slippage, rear end....more info please
Old Apr 11, 2008 | 11:25 AM
wakin3722's Avatar
wakin3722
+1 on the belt. How many miles is on the car? And when was the last tune-updone? My car did the same thing, I used a belt dressing spray. Cleared the squeak right up. Or maybe you need to change the belt. Good luck.
Old Apr 12, 2008 | 02:51 AM
groundpounder's Avatar
groundpounder
Sith Lord/Site Mod
I immediately went to belt in my mind. Check your idler pulley tension. Also, take a bar of soap and find a place to safely touch it to the ribbed side of the belt with the car running. BE CAREFUL!!!!
Take the car out for a spin and if your sqeaking stops, you have your smoking gun. New belt. If you do this and still have the squeak, give us some more detail...
drfister
May 3, 2018 10:38 PM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
tmdm
Sep 4, 2015 06:45 PM
gus_vb
Aug 29, 2015 11:35 PM
kdryan
Aug 21, 2015 09:47 PM
