Cam Idle Tune Installed on my 2013 GT!
New tune installed. Check it out!
The only exhaust modification for the car is a Pypes Pype Bomb Axle Back Exhaust and the new tune sounds great at idle. I got the tune just for car shows and meets though as using this tune makes the car run REALLY rich at idle and will kill your cats with every day use. Also, being that I have a JLT cold air intake installed on my 2013, Steeda had trouble getting the car to run right even after a tune revision stating the JLT causes a bad MAF signal. I had to increase the idle to 800 rpms to get it to stay running for the video and the driveability of the car is pretty bad. Steeda said they won't be offering the tune for the JLT cold air intake anymore but if you have a Steeda or Airraid intake, they said it should be fine and the driveability is fine. But as you can hear, the car sounds pretty awesome with the cam idle tune and definitely will turn heads at car shows
