2007 Mustang v6 ac knob problems
2007 Mustang v6 ac **** problems
So this has been happening for a while. When I am in the car most of the time the only way the account will blow out cold air is if I hold the thermostat **** all the way to cold. If I let it go 60 percent of the time it will start blowing hot air. Sometimes if will stay cold it is a gamble. Is there some kind of cable problem or is this a **** issue?
It's all electronic, the HVAC controls. Look for a replacement, just the HVAC
area.
https://www.ebay.com/itm/2005-2009-F...s/163199290638
THIS one is a steal, the entire bezel with the upper buttons. The info/setup/reset module
sells for $50.00 alone... Plus it has the TCS button, even if you don't have it,
doesn't matter.
I need a TCS button, to use as an AMP on/off switch, so it looks factory...
area.
doesn't matter.
I am not sure. I have not got in there to check yet. I know that all those lights went out a while ago except for the actual stereo itself and my aux jack. It seemed to happen with the lights and my aux connection when my battery died and they reinstalled a new one. That is a whole other can of worms. I called Ford about it and they told me it would be 85 dollars just to reprogram the aux jack in the computer.
top of the bezel; power point, TCS button, and so on...
