2005-07 MUSTANG HANDLING PACK?
Old Apr 21, 2007 | 09:19 PM
Agleon's Avatar
Agleon
Default 2005-07 MUSTANG HANDLING PACK?
Will I need anything else if I buy the Handling Pack from Ford Racing? Or if I go with the Saleen kit
Old Apr 21, 2007 | 09:54 PM
RodeoFlyer's Avatar
RodeoFlyer
Default RE: 2005-07 MUSTANG HANDLING PACK?
the FRPP pak is good. I've ridden in a GT with the Saleen kit and it rides like $hit
Old Apr 22, 2007 | 12:13 AM
jims05GT's Avatar
jims05GT
I just had the FRPP handling pack installed on my 05 GT, The ride is STIFFby I love it. The car is just a better handling car now. Corners dead flat even in hard cornering, ZERO body lean or sway. The read end is much tighter also, and no bump steer evenover rough roads.I had my local ford dealer install and align.If you follow the instuctions and notch the lower bolt holes on the front struts and use the supplied cam bolts you can get the alignment dead on (my dealer gave me an alignment report and alignment met all specs So you should'nt need and adjustable cam bolts, although BMR fabrication and others sell those .I did ask them to install an adjustable panhard rod (from BMR fabrication) so the body would be centered over the rear axle. Next project Short throw shifter. Then exhuasts, and cold air intake and finally wheels and tires. Oh yeah the instructions for notching the boltholes are included in the kit
Jim
Old Apr 22, 2007 | 01:32 AM
Agleon's Avatar
Agleon
I plan on having it installed by "PROs" I don't need LCA? Bumpsteer? ........
Old May 6, 2007 | 02:25 PM
PONYRAGE's Avatar
PONYRAGE
FRPP handling pack FTW!
Old May 6, 2007 | 04:11 PM
howarmat's Avatar
howarmat
s197 Junkie
Read below:
https://mustangforums.com/m_1696246/tm.htm
Old May 8, 2007 | 01:45 AM
philbreeziak's Avatar
philbreeziak
FRPP Handling Pack rules! I agree with the assessment by Jims05GT. It's just a great handling car now and more fun to drive than stock. I did not add any other gizmos, not sure I need anything but new rubber sooner rather than later!
Here's a pic of the back end with the camera pointed up from the asphalt.
[IMG]local://upfiles/48527/DE96C45FD43A434DB6E96DF809664EA7.jpg[/IMG]
[IMG]local://upfiles/48527/EFE54721A4764C3FB817CD0F854E6A58.jpg[/IMG]
Old May 8, 2007 | 02:48 AM
RodeoFlyer's Avatar
RodeoFlyer
the easiest way to explain bumpsteer is when you hit a rut or bump and the steering wheel jerks. it's a change in toe in relation to the suspension travel. with that kit it shouldn't be too big of an issue.
it would be wise to get an adjustable panhard bar. the rear always moves - it's physics. guys always claim "mine was okay" - that's bs
what headlights are those? they look great!
Old May 8, 2007 | 05:17 AM
dseid2's Avatar
dseid2
The FRPP Handling Pack or equivalent is amust forMustang handling. I went with the following suspension components, professionally installed: EibachPro Kit, FRPP Dampers, Steeda Strut Tower Brace (billet), Steeda front and rearsway bars, Steeda adjustable panhard bar and brace and Steeda LCA's
A set ofLCA's and anadjustable panhard bar will really completethe FRPP Handling Pack. The Eibach Pro Kit I installed lowers the S197 about 1.5 inches, similar to the FRPP lowering springs.Notice that Ford does not recommend things like camber adjusters, bump steer kit or the contol arm relocation kit with this change in ride height. If you don't go crazy with the ride height you probably won't need these components.I have not had to add these components to my car and I have hadmy parts on for the last 4,000 miles.My tire wear is good and the handling is greatlyimporved, but a little stiff.
Good luck with your Stang.
[IMG]local://upfiles/63299/6481F98FF3A44342B4E4329D3F97DE01.jpg[/IMG]
[IMG]local://upfiles/63299/5F6EF48174FC4B3E9C741628446D8989.jpg[/IMG]
[IMG]local://upfiles/63299/ABE1BB145D954C3E93F60F2A75CA4ED0.jpg[/IMG]
Old May 8, 2007 | 09:22 PM
ilmor's Avatar
ilmor
I havent driven a Mustang w/out the Ford handling kit, but I can tell you the car handles like its on rails with it. I also love the stiff, race-car like ride.[8D]
squishbang
Suspension
Nov 2, 2015 03:42 PM
krazykevin
Aug 18, 2015 08:42 AM
01moostanggt
Suspension
Aug 13, 2015 07:48 AM
daytooday
Aug 11, 2015 09:22 AM
Mnuckolls
Aug 9, 2015 08:54 AM
