285?
Old Apr 11, 2008 | 11:56 AM
Stoenr's Avatar
Stoenr
Default RE: 285?
ORIGINAL: RHuckster
I'm running 285/40/18's on my black bullitt 18x10's in the rear, 285/35/18 would beto short & you would see a much larger gap between your wheel well. You would also have to have a programmer to adjust for tire size.
Rick
+1
Old Apr 11, 2008 | 02:10 PM
zkiller's Avatar
zkiller
Default RE: 285?
285/35/18 is only 25.9" tall. Stock tire height is 27" on these cars. That is a retarded size for your car. It will look too short in the wheelwell and it will affect your gear ration and make you have less traction.
Go with 285/40/18 it is almost exactly 27" and it is made for a 10" rim.
(You can go to 305 on a 10" rim so stop worrying about a 285 being too wide.)
Old Apr 11, 2008 | 08:32 PM
AmericanICON's Avatar
AmericanICON
Default RE: 285?
ORIGINAL: Heavyg72
I have the Black DD 18x10's on the rears and went 295/45. I wanted a wide tire for the rears but it's not a DD so I'm not too concerned with tire rotation. I did use the SCT to adject the tire rpm's as the 295/45 are a bit taller than stock.
295/45/18 is awesome. I just got those for the rearwith 18x10 Bullitts.Since they are a little taller than stock, they give the car a great muscle car stance---and fills out the wheel wells nicely to the point that lowering springs aren't totally necessary to make it look good.
Old Apr 12, 2008 | 01:35 AM
Savanah07's Avatar
Savanah07
Default RE: 285?
ok coo... i originally wanted to go with 285, and went with 275, but they haven't shipped my rims yet, so i will call and switch to 285. i was just worried that i might wear my tires out bc of the fitting on the rim could cause it...
Old Apr 12, 2008 | 09:58 AM
VerginaStang's Avatar
VerginaStang
Default RE: 285?
as promised- 285/40/18 in the rear, 255/45/18 in front- Nitto's. GT500 Chrome Replica's. Steeda Sport Springs for the lowering. (As I fill my car with 93 octane $3.61/gal gas [:@]
^ thats a pic before the drop, from behind.
drfister
May 3, 2018 10:38 PM
mustanggtnsc
Jul 18, 2006 03:56 AM
adherrera722
Jun 4, 2006 09:22 AM
40thgtfl
May 23, 2006 10:40 PM
baginoman
May 11, 2006 10:47 AM
