Quantum Brak Ducts Installed
Old Jul 15, 2008 | 10:52 PM
  #21
RodeoFlyer's Avatar
RodeoFlyer
Default RE: Quantum Brak Ducts Installed
good stuff guys!
Old Jul 16, 2008 | 10:41 PM
  #22
bscottmsforums's Avatar
bscottmsforums
+1 Carbotech
+1 Quantum
+1 going through pads and rotors
One weekend at Sebring, a very tough track on brakes, cost me front rotors (warped) and a full set of pads. These cars are just heavy beasts.
I'm now running a dedicated set of track rotors so the carbotech compound doesn't mix with the ford stock pad compound. Ran VIR most recently, very fun.
Old Jul 17, 2008 | 07:17 AM
  #23
Argonaut's Avatar
Argonaut
ORIGINAL: bscottmsforums
+1 Carbotech
+1 Quantum
You actually warped a set of rotors - wow. Did you pull them off and test them to prove they warped or is it possible the 'shimmy' was due to hot spots on the rotors or un-even transfer layer? Did the happen with the brake ducts on or before? Was it the OE rotors?
Im going to move to a dedicated set of track rotors too, thats a good idea, wont have to re-bed the pads every time. VIR looks like a fun track and everyone I talk to, who has been there, raves about it. Eight hour drive for me....maybe someday.
I agree these cars are heavy beasts - I really wish Ford had dropped about 400 pounds off of them. Thanks for the info.
Old Jul 17, 2008 | 07:14 PM
  #24
Import_Slaya's Avatar
Import_Slaya
Argonaut, I heard track conditions were pretty rough and that the new pavement is tearing up on some of the turns. The irony, of course,is that this is all from a Subie site. "waaah, waaah, waaaah, my all-wheel drive rally car can't handle some choppy pavement."
http://forums.nasioc.com/forums/show....php?t=1556451
What a bunch of whiners.
Old Jul 17, 2008 | 09:39 PM
  #25
Argonaut's Avatar
Argonaut
ORIGINAL: Import_Slaya
Thats funny. Those guys should be loving it - rally cars and all. The track didn't bother me in the least. The D-Specs soaked up all those bumps without any problems. Turn 1 & 2, which is ~160 degree right hander was easy, just late apex it and drive straight across the bumps. Turn 5 and 6 were the worst, no way to avoid the bumps but they really didn't bother the car.
Old Jul 17, 2008 | 09:50 PM
  #26
Sleeper_08's Avatar
Sleeper_08
Argonaut
I was wondering what you had your D specs and tire pressures set to on the track. I'm running 2 front and 2.5 rear and 40 psi hot all round.
Old Jul 17, 2008 | 10:57 PM
  #27
bscottmsforums
ORIGINAL: Argonaut
+1 Carbotech
+1 Quantum
OE rotors, prior to brake ducts (that's what prompted me to get them). They shimmied hot and cold, and I've never had an uneven transfer prior, plus when I removed them and took them to see if I could get them turned to salvage a backup pair, the response from the shop was, "Boat anchors". So I assume that yes, they were in fact warped.
Old Jul 18, 2008 | 07:16 AM
  #28
Argonaut's Avatar
Argonaut
ORIGINAL: Sleeper_08
Argonaut
I run the D-Specs 2 Front, 4 Rear. Falken RT-615s:40 front,38 rear Hot. I also have -2 degree camber in the front which really makes it stick. I developed this setup on AX courses but it seems to work really well on the track also. Of course I have a lot less power than you but my rear is really plantedand Ill only push the font end if I make some bonehead move.
My next set of tires will be Nitto NT-01s. From what I hear they like lower pressures, probably have to experiment a little with them.
Old Jul 18, 2008 | 07:21 AM
  #29
Argonaut's Avatar
Argonaut
Ok, thanks for the info. Its amazing how hot the braking system can get. So what rotors are you running now? As mentioned in a previous post, I toasted my rotors. Replaced them last night with the Motorcraft version. This was not my first choice by any means but Im off to Pocono and was in a fix to get some new ones asap. I dont have high hopes for them and they weren't exactly cheap at the stealership. Ill see how they hold up with the ducts.
Old Jul 18, 2008 | 11:56 AM
  #30
bscottmsforums
ORIGINAL: Argonaut
take offs....Good luck!
