First autoX coming up
#32
Are you shipping the broken one back to them for them to inspect? If so it would be interesting to hear the explanation for the failure - if you get one.
#33
Wow... that is some seriously thin wall tubing right there. And it looks like it actually tore the metal. Hopefully it was just some bad metal, because a car on Toyo's shouldn't have done that to a swaybar under normal conditions.
It's great to hear they warrantied it without hassle.
I would like to know more about the bar.... like the OD, the wall thickness etc. There isn't anything on their website regarding real world information.
#35
Sleepless is correct, the tubing was not welded properly. Fortunately, Griggs original shoppe was at Infineon Raceway and is only 10 mintues away. This is where I brought it to do the original work and subsequent upgrade to SLA. They have since relocated, middle of it actually, to Petaluma and that is only 15 minutes away. I just brougt the two pieces up there and spoke with John directly. He had a little pow-wow with Bruce and decided that it should not have broken and just gave me a new one. They offered to install it, but didn't want to have to go back up later this week to pick it up. I just installed it a few minutes ago and took only 1/2 hour.
Sam, as far as its dimensions, it is quite thin and would say no more than 1/8" thick (maybe only 3/32") tubing and 1.5" diameter. The strange part is what I could have done on Saturday, rather than leaving event. John said I should have just removed the parts and continued the autoX event! He went so far as to say, if I had a Watts-Link rear instead of a PHB, I could have just lowered that one peg (to lower roll-center) and probably not even noticed the front bar was even missing! He said the front bar is almost not even necessary with the Griggs set-up. Sho nuff, on the way home I tugged the wheel a few times on some minor twisites and was just fine. Still VERY responsive and only the slightest additional roll. He said the only issue I may have had at autoX w/o bar, was possibly some tire rubbing due to 295's up front.
So anyway, all fixed up and red-to-go for next autoX event. I am picking up some good helmets for galpal and I as the ones we had pretty much sucked. I will also bring the toolbox from my truck as it has all the wrenches I needed to re-install the new bar just now. As it was, I had to borrow a 10" & 12" Crescent wrenches and was a PITA to remove.
The Jaz
#36
1.5" OD with approx. 3/32" wall. Ok, that's what I wanted to know.
As for the running w/o the front bar thing and lowering the rear RC, I agree you could have done it. I don't think I'd classify it as "just fine" as a setup, but it wouldn't have caused you any bodily harm. If the front bar isn't necessary I wonder why they bother changing it, let alone to such a pricey part (basically I don't really buy it).
None the less, I'm glad they did the right thing for you.
#37
It is certainly prefferable to have the sway bar, but I think the major advantage of this one over the stock is the non-binding Heim joint connections. This is largely what sets this bar apart from stock aside from possible weight savings.
I too am happy it is all fixed up and have a little more knowledge of "how things work". Will be just that much more prepared next time I hit the cones.... I mean course
Jazzer The Cat
