Eibach Pro kit
Old Feb 28, 2009 | 04:56 PM
slw1000's Avatar
slw1000
Default Eibach Pro kit
Hey guys..
Got the pro kit sitting in the garage... I was thinking about changing them out tomorrow so I opened the box looking for some kind of instructions. Of course there are none...
So does anyone know which set of springs goes on the back? Is it the taller narrower one or the wider shorter one?
Also which end goes down the flat side or the one with the end of the coil? Is the snubber needed??
thanks
Old Feb 28, 2009 | 05:30 PM
Sleeper_08's Avatar
Sleeper_08
Especially when you do the fronts do them one at a time. that way you can match what your are putting on to the other side. On the front there may be a plastic piece around the coil. This should be used around the new coil.
I found a link to the TacoBill instructions - they really help http://forums.bradbarnett.net/showthread.php?t=441678
Old Mar 4, 2009 | 01:59 PM
slw1000's Avatar
slw1000
Thanks for the help. I had already seen his write up, but when I tried to put my car together nothing looked right.Turns out the parts guy at the dealer gave me the springs for an older Mustang.So I spent 2 days trying to figure out how to install the springs before I realized I was given the wrong ones.Now that I have the right ones its very obvious which ones are for the front and which are for the back. There's also instructions included in the new kit.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
mapitts
May 11, 2016 10:14 AM
jerrytubes
Oct 23, 2015 12:11 PM
