new tires?
Old Oct 3, 2012 | 07:50 PM
  #21
mth21305's Avatar
mth21305
ok well nevermind im an idiot. apparently the nt555 do not come in a 40 for a 20' wheel...kind of disappointing really but they do make a 285/35
Old Oct 3, 2012 | 07:52 PM
  #22
TRexGAWD's Avatar
TRexGAWD
Right now your fronts and rears are the same height.. If you go 295/40/20 in th rear that is an extra two inches which is huge. I don't think you'll clear, especially if you're the slightest bit lowered. Just stick with correct tire size.. either a 295/30 or a 275/35 if you want just a bit taller in the rear..
Old Oct 3, 2012 | 08:33 PM
  #23
mth21305's Avatar
mth21305
think a 295/35 rear would work?
Old Oct 3, 2012 | 08:56 PM
  #24
TRexGAWD's Avatar
TRexGAWD
You're killing me man.. I've mentioned a tire size.. that is all
Old Oct 4, 2012 | 05:01 AM
  #25
mth21305's Avatar
mth21305
Sorry, i am not trying to be a pain in the *** here but i think im just confused as to why the rear tire would be a 30 and the front would be a 35? I would think the aspect ratio would be the same front and rear, it is the same size rim after all?
Old Oct 4, 2012 | 06:30 AM
  #26
Norm Peterson's Avatar
Norm Peterson
Those 30 and 35 numbers really are tire section heights expressed as percentages of the tire width. IOW, a 295/30 tire will have a height of about 295 x 0.30 or about 88.5 mm.
A 255/35 works out to a height of about 89.3 mm. Trust me, you'll never see that 0.8mm difference even if you stood the two tires back to back. Not even if both tires measured out at precisely the advertised size numbers (most tires don't, exactly).
The 30, 35, 40, or whatever, are NOT absolute height numbers by themselves, and continuing to focus only on them will only keep you confused.
Norm
Old Oct 4, 2012 | 10:41 AM
  #27
TRexGAWD's Avatar
TRexGAWD
The aspect ratio is a ratio to the width of the tire.. Like norm said, it's a ratio to the 255 for the front.. Having a 295/30 will have a sidewall height of about 3.45 inches.. a 255/35 in the front has a sidewall height of about 3.48 inches... That is close enough to be even..
You want the heights to be close to matching.. A 295/35 is roughly a 4 inch sidewall, putting your overall rear height at 28 inches and your front at 27 inches.. It will have a slight raked appearance and will also cause a speed mismatch due to a taller tire in the rear, which will require a recal of the speedometer.. A taller tire also increases overall gearing, like going from a 3.73 rear to a 3.55 rear nearly, reducing your overall performance/driven torque...
These are your tire options I would stick with..
275/35/20
285/30/20
295/30/20
305/30/20 (you'll start running into fitment issues at this width)
Old Oct 22, 2012 | 05:27 PM
  #28
mth21305's Avatar
mth21305
kind of a stale post but i finally got the tire thing figured out lol. I am going to go with matte black machined AMR wheels 18x9 and 18x10 with nitto 555's 255/45/18 and 285/40/18. anybody have any suggestions on the look or tire performance?
Old Nov 2, 2012 | 05:45 PM
  #29
7gtthrilla's Avatar
7gtthrilla
I've been through a few sets through the past three years. I started with the Toyo Proxes4. They were way too soft and had no traction in the rain. My dad has an 08 cobra with Goodrich tires. He upgraded to Nitto 05's so I got the old slightly used tires. They worked well for my GT but I kind of got sideways and stayed there often so yeah. I used the stock tires for a while to save up for the Nitto555's and man when I got them, amazing difference. Traction is great all around, especially on hot days and they look great. To say the least, I'm very happy with my Nitto555's.
Old Nov 4, 2012 | 07:21 AM
  #30
Norm Peterson
If you haven't bought them already, do a little photo editing with your car and those wheels, resizing the wheels to fit the car in the same scale.
Save the resulting picture and don't even look at it for a few days. Not at all. Then pay attention to your first reaction when you do look at it again.
Norm
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
