Clutch not disengaging
Old 04-19-2018, 09:59 PM
Edgestrated
Edgestrated's Avatar
Default Clutch not disengaging
i have a 2003 mustang GT 4.6, I’m having problems with the clutch not disengaging. At first it wouldn’t happen until after 20 minutes or so of driving and then I randomly wouldn’t be able to put the car in first gear or reverse. I could force the car in to second and then it would seem like it was shifting fine, but I still wouldn’t be able to get into first gear once I stopped. I’ve inspected the clutch cable and saw nothing wrong with it. What could be causing this? I think the cable was replaced with an after market one by the previous owner, should I change it back to the stock cable?
Edgestrated is offline
Old 04-20-2018, 12:18 PM
Z28KLR
Z28KLR's Avatar
Maybe just an adjustment issue? Assuming it still has the stock quadrant, the clutch cable is adjusted by pulling firmly upward on the clutch pedal until it clicks/pops. Try that and see what happens.
Z28KLR is offline
Old 04-20-2018, 12:26 PM
You have to take out some slack from the cable. Either at the firewall adjuster ( assuming they used one ) or at the quadrant on the pedal. Pulling up on the pedal gives more slacke. To take the slack out you have to push the pedal to the floor while laying on your back and use a large screwdriver to hold the quadrant assembly still, then rais the pedal. It will click as the paw rides the teeth on the quad. You should be good with 1 or 2 clicks.
Danielsmustang
04-21-2018 02:52 PM
darkstarnes
06-09-2013 08:42 PM
Unsullied_Spy
03-14-2010 12:59 AM
NKGT
04-26-2009 03:07 AM
ewgoetz
07-28-2008 10:14 AM
Quick Reply: Clutch not disengaging
