What’s this noise on my mustang GT
let me know what y’all think sound is coming from under shifter when I accelerate or turn sound gets louder when more people are in the car Check the exhaust nothing is loose or touching
Can be Transmission. Either something is loose in the bell housing, or a drum or
something is breaking inside. Had similar noises in my Silverado, apparently the
low/reverse drum cracked, then it finally broke. It was making all kinds of scraping
noises in first gear on acceleration, real bad in reverse. I even found friction disc teeth
in the pan when I changed the fluid and filter... It cost $1000 to have it rebuilt... It's a
known problem with the silverado, that trans...
that's a rotational sound... in neutral all's well. If a shop could put it on a lift and put in drive it might bind it up so you can see where it's rubbing.
Look for "shiny" metal under the car, on the driveshaft which would indicate the point of contact.
sixthstang
03-06-2013 09:30 AM
